I need help
Results 1 to 6 of 6
Thread: I need help
    Sep 2010
    Las Vegas, NV
    Default Re: I need help
    Probably a stupid question but in the following lines temperature is broken into a lowbyte and highbyte. Assuming you've got temperature defined as a WORD, does PBP automatically meld these two bytes together to make a WORD? I thought you had to kinda build the word or specify which byte you want to use.
    OWIN DQ,0,[temperature.LOWBYTE,temperature.HIGHBYTE]
    temperature = temperature*/1600
    Hoping I'm not too far out in left field.
    Aug 2008
    Hello thanks for the reply
    I made a modification to the program for USART 9600
    I made a correction in the temperature of the program now everything is normal functioning
    Thank you
