Negative swing with a DAC
Results 1 to 8 of 8
    Jun 2007
    Mansfield, UK
    Default Negative swing with a DAC
    Hi, I have an 8-bit DAC which is currently outputting about 0-3V. After some filtering etc this goes into the line-in of an audio amplifier.
    Line level is supposed to swing from about -1.5 to 1.5V. I've seen online that this can be achieved by "biasing" the amplifier's ground to 1.5V.
    The issue I've got is that the amplifier is powered from the same power supply as the rest of the circuit. The reference ground on the amplifier is the same as the power ground so there's no way for me to bias it.
    Is there another way to get the required swing? I feel that I need to connect my DAC to -3V instead of ground but I don't have a negative supply.
    Sep 2009
    Default Re: Negative swing with a DAC
    Just add high pass filter
    Jun 2007
    Mansfield, UK
    Sorry, I should mention that I only have 24V DC available from a switching PSU and the amplifier is single supply (not split).
    I could potentially move the entire amplifier ground up by 1.5V as 22.5V would still be enough to power it.
    A potential divider won't be suitable to hold the ground of a 100W amp though.
    Sep 2009
    Did you see my post?
    That is common way to remove dc offset and center signal around 0V.
    If it were me, I would vary the signal between 1 and 4 volts with the PIC, 2.5 volts being your artificial ground (bias) and then cap couple it to the amplifier. I have done this before with our radio repeater for the courtesy tone's.
    EN82fn
    I'm not sure why you're ignoring the idea of simply AC-coupling the signal into the amplifier but if that doesn't work for whatever reason it might be possible to use the PIC to generate a negative supply rail for the DAC using a chargepump circuit and the CCP module in PWM mode. It'll add circuitry though.
    Jun 2007
    Mansfield, UK
    pedja089:-
    I did see your post. Are you suggesting to use that circuit on the output from the DAC? I thought the sine wave was representing an AC supply.
    Dave/Henrik:-
    I've just done a bit of reading and it looks like "cap coupling", "AC-coupling" and pedja089's schematic are all the same thing. I will give that a go and see what happens.
    Henrik:-
    I have plenty of board space for once so if I do need to add extra stuff it won't be a problem.
    Sep 2009
    Yes, that circuit should be on output of DAC. And it is just first image from WEB.
  1. Ti Dac 7553
    By GeoJoe in forum mel PIC BASIC Pro
    Last Post: - 28th August 2008, 21:29
  2. Looking for a DAC
    By RussMartin in forum Off Topic
    Last Post: - 25th November 2007, 07:21
  3. Using DAC's with pics
    By J_norrie in forum mel PIC BASIC Pro
    Last Post: - 27th March 2007, 15:00
  4. i2c with a dac
    By fabritio in forum mel PIC BASIC Pro
    Last Post: - 29th March 2006, 18:13
  5. dac
    By kaisersystems in forum mel PIC BASIC Pro
    Last Post: - 10th June 2005, 21:23
