Pic will not run
Results 1 to 10 of 10
    Default Re: Pic will not run
    Just in case - If you changed the battery on the DS1307 or removed it, I believe you'll need to send the enable bit code to get it running again otherwise your time will not change but will be stuck where it was when it lost backup power.
    btw, the DS3231 is tremendously more accurate, in case you wanted that improved. It leaves the 1307 in the dust.
    Picster
    Last edited by picster; - 23rd July 2016 at 17:05. Reason: edited to include DS3231
    Oct 2009
    thanks for the comments guys,
    I've attached board layouts as requested. I've been out this afternoon, so will have a further play in reducing the ic2 pullups to see if that helps
  1. PIC16F628A Will not run at all....
    By thasatelliteguy in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2014, 08:26
  2. PIC programs, resonator resonates, but does not run code.
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th August 2012, 02:47
  3. Run-Time Config
    By Darrel Taylor in forum PBP Extensions
    Last Post: - 1st February 2012, 17:26
  4. 16F628 does not run. I can't believe this
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2009, 16:41
  5. How to run program in parallel?
    By vanxn in forum mel PIC BASIC Pro
    Last Post: - 18th July 2006, 22:59
