Pic will not run
Results 1 to 10 of 10
    Dec 2010
    Default Re: Pic will not run
    Boards can sometimes have an issue with plate through holes. If you've found one with a problem. likely all the boards in that batch will have issues - just not necessarily in the same location. Where the through hole devices are, I'd make sure the solder wicked through completely, and maybe even put a bit extra solder top and bottom to guarantee the connection. It also wouldn't hurt to solder a bit of wire in the vias and cut it off flush when done. That should address your marginal connection situation. Sometimes a track will "buzz out" fine, but contain enough resistance to make signals flaky if you've got a poorly manufactured board.
    Your pull up resistors likely need to be smaller, not larger. The trade off is that smaller resistors consume a bit more energy, but speed up the rise time of the waveform. I'd try 2K2 or 3K3. I don't think I've ever used anything over 3K9, especially with multiple devices sharing the bus. 10K is at the extreme upper limit of the spec. Unless battery life is a critical design requirement, go small. 1K is the absolute minimum, so don't go quite that far.
    Any chance you can share a picture of the board layout?
  1. PIC16F628A Will not run at all....
    By thasatelliteguy in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2014, 07:26
  2. PIC programs, resonator resonates, but does not run code.
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th August 2012, 01:47
  3. Run-Time Config
    By Darrel Taylor in forum PBP Extensions
    Last Post: - 1st February 2012, 16:26
  4. 16F628 does not run. I can't believe this
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2009, 15:41
  5. How to run program in parallel?
    By vanxn in forum mel PIC BASIC Pro
    Last Post: - 18th July 2006, 21:59
