Pic will not run
Results 1 to 10 of 10
    Oct 2009
    Default Re: Pic will not run
    Well I have the PIC running the main code, and it displays the main intro and main screen, but it's not reading the DS1307 as it displays 10:10 regardless if the DS1307 is present on the board. I've checked continuity between the SCL and SDA lines, pullups and supplies - changed the DS1307, swapped pullups from 10k to 4.7K and back, and replaced the 37Khz crysta, but still no change in the display
    disable those pins just in case this is causing the PIC to lock up
    It can't do any harm to set all grounded pins to inputs.
    Decoupling?
    Do you still have access to a working breadboard version?
    George
    Dec 2010
    Boards can sometimes have an issue with plate through holes. If you've found one with a problem. likely all the boards in that batch will have issues - just not necessarily in the same location. Where the through hole devices are, I'd make sure the solder wicked through completely, and maybe even put a bit extra solder top and bottom to guarantee the connection. It also wouldn't hurt to solder a bit of wire in the vias and cut it off flush when done. That should address your marginal connection situation. Sometimes a track will "buzz out" fine, but contain enough resistance to make signals flaky if you've got a poorly manufactured board.
    Your pull up resistors likely need to be smaller, not larger. The trade off is that smaller resistors consume a bit more energy, but speed up the rise time of the waveform. I'd try 2K2 or 3K3. I don't think I've ever used anything over 3K9, especially with multiple devices sharing the bus. 10K is at the extreme upper limit of the spec. Unless battery life is a critical design requirement, go small. 1K is the absolute minimum, so don't go quite that far.
    Any chance you can share a picture of the board layout?
    Just in case - If you changed the battery on the DS1307 or removed it, I believe you'll need to send the enable bit code to get it running again otherwise your time will not change but will be stuck where it was when it lost backup power.
    btw, the DS3231 is tremendously more accurate, in case you wanted that improved. It leaves the 1307 in the dust.
    Picster
    Last edited by picster; - 23rd July 2016 at 17:05. Reason: edited to include DS3231
    Oct 2009
    thanks for the comments guys,
    I've attached board layouts as requested. I've been out this afternoon, so will have a further play in reducing the ic2 pullups to see if that helps
  1. PIC16F628A Will not run at all....
    By thasatelliteguy in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2014, 08:26
  2. PIC programs, resonator resonates, but does not run code.
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th August 2012, 02:47
  3. Run-Time Config
    By Darrel Taylor in forum PBP Extensions
    Last Post: - 1st February 2012, 17:26
  4. 16F628 does not run. I can't believe this
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2009, 16:41
  5. How to run program in parallel?
    By vanxn in forum mel PIC BASIC Pro
    Last Post: - 18th July 2006, 22:59
