Data from DS1307 (BCD) saved to ext memory and read back to display
Results 1 to 11 of 11
    SWITZERLAND (french speaking)
    Default Data from DS1307 (BCD) saved to ext memory and read back to display
    Hi there,
    I have setup a 16F690 reading a DS1307's time and date (I use RA2/INT interrupt to trigger the process every second), save this data to an external 24LC64 memory, read back what has just been written from the memory and display it.
    If I bypass the I2CWRITE/I2CREAD commands, the DS1307 displays time correctly.
    But, like in the code here under, after saving RTC's time to the memory, this is what I get after reading back the data from the external memory:
    Name:  2016-07-18 23_56_00-LCD Module.jpg
    Data from DT1307 is in BCD format and data conversion, that's where I think I'm wrong, is not my cup of tea
    What am I missing?
    ' PIC 16F690 Fuses (MPASM)
    @ __Config _FCMEN_OFF &_IESO_OFF &_CPD_OFF &_WDT_OFF &_HS_OSC &_BOR_OFF &_CP_OFF &_PWRTE_OFF &_MCLRE_OFF
    ' Registers   76543210
    OPTION_REG = %10000000 'PORT A&B Pull-Ups disabled (look WPUA & WPUB) INTEDG rising edge on A2
    ANSEL      = %00000000 'Analog inputs Channels 0 to 7
    ANSELH     = %00000000 'Analog inputs Channels 8 to 11
    ADCON0     = %00000000 'A/D Module is OFF
    CM1CON0    = %00000000 'Comparator1 Module is OFF
    CM2CON0    = %00000000 'Comparator2 Module is OFF
    INTCON     = %00010000 'INTerrupts CONtrol
    TRISA      = %00000100 'Set Input/Output (0 to 5)
    PORTA      = %00000000 'Ports High/Low (0 to 5)
    TRISB      = %00010000 'Set Input/Output (4 to 7)
    PORTB      = %00000000 'Ports High/Low (4 to 7)
    TRISC      = %00000000 'Set Input/Output (0 to 7)
    PORTC      = %00000000 'Ports High/Low (0 to 7)
    ' Defines
    ' Variables
    SQW         VAR PORTA.2     'DS1307's 1Hz output
    D_Out       VAR PORTB.7     'serial data out for display
    SCL         VAR PORTC.0     'DS1307 clock line
    SDA         VAR PORTC.1     'DS1307 data line
    DB0         VAR BYTE(8)
    DB0(0)      = 0 ' Seconds (00-59)
    DB0(1)      = 0 ' Minutes (00-59)
    DB0(2)      = 0 ' Hours (00-23)
    DB0(3)      = 0 ' Day (01-07; 1=Sunday, 2=Monday, ...)
    DB0(4)      = 0 ' Date (01-31)
    DB0(5)      = 0 ' Month (01-12)
    DB0(6)      = 0 ' Year (00-99)
    DB0(7)      = 0 ' Control (see datasheet)
    D_Bps       CON 16468   ' 9600 Driven Inverted None
    ' Initialize
    ' Program
    ON INTERRUPT GOTO Read_DS1307
    MAIN:
        GOTO MAIN:
    ' Interrutp Service Routine
    DISABLE
    Read_DS1307:      ' Read time Secs,Mins,Hours,Day,Date,Month,Year,Control
        I2CREAD SDA,SCL,$D0,$00,[STR DB0\8] ' Read 8 bytes from DS1307
        ' Write to external memory
        I2CWRITE SDA,SCL,$A0,$00,[DB0(2),DB0(1),DB0(0)]
        PAUSE 10
        'Read from external memory
        I2CREAD SDA,SCL,$A0,$00,[DB0(2),DB0(1),DB0(0)]
        SEROUT2 D_Out,D_Bps,[HEX2 DB0(2),":",HEX2 DB0(1),":",HEX2 DB0(0),13,10]
        INTCON.1 = 0  'clear INTF interrupt flag
        RESUME
    ENABLE
    Roger
    Oct 2009
    Default Re: Data from DS1307 (BCD) saved to ext memory and read back to display
    Hi Roger, I'm no expert, but maybe this can be of some use.
    I have these variables to display the time on an LCD
    TimeH           var byte                 'variable to store Hours
    TimeM           var byte                 'variable to store Minutes
    SS              VAR Byte                 'variable to store Seconds
    RTCsec          var byte                'RTC Seconds
    RTCMin          var byte		        'RTC Minutes
    RTCHour         var byte	            'RTC Hours
    I then read the DS1307 and convert the BDC value into time as follows
    I2CRead SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour]   ' read the RTC
    timeH=(RTCHour>>4)                        'convert the BCD format of the hours register and store in variable timeH
    timeH=(timeH &$03)*10
    timeH=timeH+(RTCHour&$0F)
    timeM=(RTCMin>>4)                         'convert the BCD format of the mins register and store in variable timeM
    timeM=(timeM &$07)*10
    timeM=timeM+(RTCMin&$0F)
    ss=(RTCSec>>4)                            'convert the BCD format of the sec register and store in variable ss
    ss=(ss &$07)*10
    ss=ss+(RTCSec&$0F)
    LCDOut $FE,$C0+11,#TimeH DIG 1,#TimeH DIG 0,":",#TimeM DIG 1,#TimeM DIG 0          'display the current time on the LCD
    Now maybe (I don't know as I've never written to an external e-prom) you can save the byte variables for TimeH, TimeM and SS with something like
    I2Cwrite SDApin,SCLpin,$insert address of eeprom,[TimeH,TimeM,SS]
    Like I said, I'm no expert, and may be sending you off on a tangent !!
    Forgot to add, this is the routine to convert to BDC if required
    CounterA=SetMN
    Gosub ConvertBCD
    RTCMin=CounterB
    CounterA=SetHR
    Gosub ConvertBCD
    RTCHour=CounterB
    I2Cwrite SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour]
    ConvertBCD:
    	CounterB=CounterA DIG 1                        ' CounterA is the entry variable
    	CounterB=CounterB<<4                           ' CounterB holds the converted BCD result on exit
    	CounterB=CounterB+CounterA DIG 0
    CounterA and CounterB are byte variables, as are setHR and setMN. I used these as the initial time to display on the LCD. For example I want to set the initial time to 12:00 I use 12 for setHR and 0 for setMN. If you need to convert from decimal to BDC before sending to the eepprom, then maybe this bit of code can help ??
    Malcom is nearly correct
    should be
    I2Cwrite SDApin,SCLpin,$a0,eprom_location,[TimeH,TimeM,SS]
    where :- for a 24lc64 8k bytes and 32 byte page size
    1. eprom_location must be a word var
    2. eprom_location must be < 8192
    3. ( eprom_location//page_size ) < (32 -number_of_bytes to write ) ie don't try to write past a page boundary
    ps can't see the need for bcd - bin - bcd conversions though
    Oct 2009
    Hi Richard, nice to know I was almost there
    Roger stated that the RTC uses BDC format, which needs converting
    I presume that once you've converted the BDC format and stored them into variables as decimal values for hours and minutes you would then simply write those to the external memory, although they would need to be word variables, so would this be correct ?
    I2Cwrite SDApin,SCLpin,$a0,eprom_location,[TimeH.lowbyte, TimeH.highbyte,TimeM.lowbyte, TimeM.highbyte,SS.lowbyte, SS.highbyte]
    Assuming TimeH, TimeM and SS are all declared as word variables
    Quote Originally Posted by Scampy View Post
    ...you would then simply write those to the external memory although they would need to be WORD variables...
    I thought only the address variable must be WORD sized?
    Name:  2016-07-20 20_41_53-Memory-24LC64_serial-I2C-EEPROM.pdf - [24AA64_24LC64 64K I2C Serial EEPROM] .jpg
    Roger
    Well,
    I'm still making some mistake somewhere.
    The display says now "55:55:55".
    If I bypass the I2CWRITE and I2CREAD commands, everything is fine
    'OSCCON     = %01100000 'Internal RC set to 4Mhz - not to be used with XTal
    ' Defines
    ' Variables
    SQW     VAR PORTA.2 ' RTC 1Hz output
    D_Out   VAR PORTB.7 ' serial data out
    SCL     VAR PORTC.0 ' RTC clock
    SDA     VAR PORTC.1 ' RTC data
    RTC_Sec VAR BYTE    ' Seconds (00-59)
    RTC_Min VAR BYTE    ' Minutes (00-59)
    RTC_Hou VAR BYTE    ' Hours (00-23)
    ' Initialize
    PAUSE 1000                      ' power-up serial-LCD
    SEROUT2 D_Out,D_Bps,[27,"C",0]  ' set serial-LCD cursor OFF
    SEROUT2 D_Out,D_Bps,[27,"L",0]  ' set serial-LCD backlight OFF
    ' Program
    MAIN:
        GOTO MAIN:
    DISABLE
    Read_DS1307:
        I2CREAD SDA,SCL,$D1,$00,[RTC_Sec,RTC_Min,RTC_Hou]
        ' Convert Hex coded to decimal
        RTC_Sec = (RTC_Sec & $F)+((RTC_Sec >> 4)*10)
        RTC_Min = (RTC_Min & $F)+((RTC_Min >> 4)*10)
        RTC_Hou = (RTC_Hou & $F)+((RTC_Hou >> 4)*10)
        I2CWRITE SDA,SCL,$A0,$00,[RTC_Sec,RTC_Min,RTC_Hou]
        PAUSE 10
        I2CREAD SDA,SCL,$A0,$00,[RTC_Sec,RTC_Min,RTC_Hou]
        SEROUT2 D_Out,D_Bps,["Time: ",DEC2 RTC_Hou,":",DEC2 RTC_Min,":",DEC2 RTC_Sec,13,10]
        INTCON.1 = 0
        RESUME
    ENABLE
    Roger
    Sep 2009
    Address should be word or byte variable, not constant.
         MemAdr var word
        MemAdr =0
        I2CWRITE SDA,SCL,$A0,MemAdr ,[RTC_Sec,RTC_Min,RTC_Hou]
        PAUSE 10
        I2CREAD SDA,SCL,$A0,MemAdr ,[RTC_Sec,RTC_Min,RTC_Hou]
    EDIT:
    Constant works for clock, as PBP send minimum 8 bits, but it wont work for EEPROM as it expecting 16bits.
    I mention that in another topic.
    Oct 2009
    I have a project that sends values from 0 to 4096 to an 16 channel PWM led driver chip, and this is a sample line of code
      I2CWRITE SDApin,SCLpin,i2cWriteAddress,i2cControl,[0,0,CH1_PWM.lowbyte,CH1_PWM.highbyte]
    The reference to word variables I made was because your external eprom is expecting 16 bit values for the data, hence my reference to making your TimeH, TimeM and TimeS word variables, and trying the lowbyte / highbyte approach. - Like I mentioned in my first reply, I'm no expert, and this may be taking you off tangent, but then again, might be worth trying
    Okay, I haven't declared the address as a variable at all.
    So I'll give it a try a little later (I'm in the office right now).
    ...your external eeprom is expecting 16 bit values for the data.
    This is confusing me. I think the 24LC64 needs data in BYTE format as where it's addresses are in WORD format.
    Roger
    That is correct. The 24LC64 data is 8 bits wide per individual location. CH1_PWM.lowbyte,CH1_PWM.highbyte is the correct way to sequentially load data into the eeprom if the variable is a word.
    EN82fn
    Thumbs up Defining eeprom address made it work
    It works!
    I declared the EEPROM address as WORD, replaced the $00 in the I2CWRITE and I2CREAD commands and now the result is okay.
    Thanks a lot for the help
    ' Defines
    ' Variables
    Eep_Adr VAR WORD
    Eep_Adr = $00
    ' Initialize
    ' Program
    MAIN:
        GOTO MAIN:
    DISABLE
    Read_DS1307:
        SEROUT2 D_Out,D_Bps,["HEX: ",HEX2 RTC_Hou,":",HEX2 RTC_Min,":",HEX2 RTC_Sec,13,10]
        ' Convert Hex coded to decimal - can be usefull for external memory data storage (logging)
        I2CWRITE SDA,SCL,$A0,Eep_Adr,[RTC_Sec,RTC_Min,RTC_Hou]
        PAUSE 10
        I2CREAD SDA,SCL,$A0,Eep_Adr,[RTC_Sec,RTC_Min,RTC_Hou]
        SEROUT2 D_Out,D_Bps,["DEC: ",DEC2 RTC_Hou,":",DEC2 RTC_Min,":",DEC2 RTC_Sec,"   "]
        RESUME
    ENABLE
    Thank you Dave for explaining the WORD sized eeprom data.
    Before I started this thread, I didn't know about "packed BDC". I think it can be interesting to reduce data size especially when, like in my current project, time data has to be stored in external memory.
    Roger
  1. Replies: 2
    Last Post: - 3rd January 2013, 17:57
  2. DS1307 - How to store Decimal Value & how to convert back to BCD?
    Last Post: - 3rd January 2011, 00:44
  3. loading data to EXt. eeprom
    By MINHLE in forum General
    Last Post: - 28th December 2009, 18:56
  4. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 20:19
  5. cannot read/write to 16F690 data memory after CPD_ON
    By awdsas in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2006, 12:46
