starting with I2C read/write devices addressing
Results 1 to 4 of 4
    SWITZERLAND (french speaking)
    Default starting with I2C read/write devices addressing
    I'm just starting a project involving the use of an external EEPROM. I think about to use a 24LC64 (that's is what I could find in my drawer...).
    After ten years playing with PICs, I've still never used external mem chips before neither experimented I2C
    As a first step, on my breadboard, I put up a 16F690, a DS1307 (RTC) and the 24LC64.
    Just for the exercise, my program will read the RTC and store (kind of time stamp) it in the external memory.
    Before doing that, I found TimC's I2C device scanner just to make sure my devices "respond" correctly.
    The I2C scanner "sees" both devices (DS1207 + 24LC64) but here starts my interrogation: for each device, I get two "addresses". For the 24LC64 I get $A0 and $A1 and for the DS1307 I get $D0 and $D1.
    What does this mean?
    Roger
    Sep 2009
    Default Re: starting with I2C read/write devices addressing
    Bit 0 is RW bit, and PBP set it automatically.
    Your device address is $A0 and $D0.
    For RTC address variable MUST be byte, for your EEPROM address MUST be word. This is because PBP will send 8 or 16 address bits depending on what type variable is used, as far as I know. And RTC expect 8bit address, EEPROM 16bit.
    64K eeprom is not 64KB it is 64Kbit, which is 8192 bytes.
    This answer is loud and clear
    I'll give it a try now.
    Thanks a lot, pedja089.
    Roger
    Sep 2009
    You are welcome.
  1. I2C Write & Read
    By dallowgill in forum mel PIC BASIC Pro
    Last Post: - 15th June 2011, 00:06
  2. I2c write&read
    By MINHLE in forum General
    Last Post: - 6th January 2010, 00:13
  3. I2C Read and Write
    By DerekMacom in forum mel PIC BASIC
    Last Post: - 21st April 2008, 16:44
  4. A help with Write/Read a I2C memory
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 28th March 2008, 14:53
  5. Internal EEPROM Read/write Addressing Errors with 18F PIC's
    Last Post: - 12th July 2005, 20:42
