Hello,
I use the version PBP 4.0.0.0 and MPLAB 8.92.
the quartz is a 4mhz.
I can send you, if you want the program of my editing, if this allows you to better understand.
pascal
pbp version is v3.x.x.x or 2.xxversion 4.0.0.0 is the microcode studio version
my previous reply is one way that will do it for pbp 3.xxxI would like to know if I can and how to program the fuse bits in pbp and know how this is written.
its done differently for pbp 2.xxx . I have not used that old version for several years and can offer no help for it
meconfig suggests this
Code:ASM __config _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L __config _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H __config _CONFIG2L, _PWRT_OFF_2L & _BOR_ON_2L & _BORV_3_2L & _VREGEN_ON_2L __config _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H __config _CONFIG3H, _CCP2MX_ON_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_OFF_3H __config _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L __config _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L __config _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H __config _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L __config _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H __config _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L __config _CONFIG7H, _EBTRB_OFF_7H ENDASM
