Is it possible to interpret non-standard serial data with PicBasic (sample attached) - Page 2
Page 2 of 2 FirstFirst 12
Results 41 to 61 of 61
  1. #41
    Post Re: Is it possible to interpret non-standard serial data with PicBasic (sample attach
    as close as I can get . it has a glitch after the last bit sent
    '*  Name    : MODULATOR.BAS                                     *
    '*  Notice  : Copyright (c) 2016 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 5/29/2016                                         *
    '*  Notes   :                        *
    '*          : 16F1825                                           *
                 __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_ON  &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
                  __config      _CONFIG2, _PLLEN_OFF & _LVP_OFF
    OSCCON=$70
    DEFINE OSC 8
    '                       PIC 16F1825
    TRISA     = %011111    '
    trisc     = %001111  ;
    ANSELA=0
    ANSELC=0
    MDSRC=    %00000000
    MDCARH   =%01000100
    MDCARL   =%00000000
    X VAR byte
    darta   VAR byte[4]
    TIMER1     VAR WORD EXT
    clear
    modout var latc.4
    darta.0[14]=1
    darta.0[15]=1
    t2con=6
    pr2=158
    CCPR1L =318>>2
    ccp1con=12
    MDCON.0 = 0
    modout =1
    Main_Loop:
    lata.5=1 ; cro trigger
    while !pir1.1 :wend
    modout=0
    pauseus 9900
    modout =1
    pir1.1=0
    while !pir1.1 :wend
    pir1.1=0
    while !pir1.1 :wend
    MDCON=    %11000001
    pir1.1=0
    while !pir1.1 :wend
    for x = 0 to 31
    if  darta.0[x]  then
    MDCON.0 = 0
    pir1.1=0
    while !pir1.1 :wend
    pir1.1=0
    while !pir1.1 :wend
    MDCON.0 = 1
    pir1.1=0
    while !pir1.1 :wend
    MDCON.0 = 1
    pir1.1=0
    while !pir1.1  :wend
    next
    modout = 1
    MDCON = 0
    lata.5=0
    PAUSE 200
    goto Main_Loop
    Default Re: Is it possible to interpret non-standard serial data with PicBasic (sample attach
    Thanks!
    I guess, your code can run on 16F1829 ?
  3. #43
    should do they are the same except for a few extra pins
    well the dsp module is interesting but for this project perhaps its easier to do it the old way
    '*  Notes   :                        *
    '*          : 16F1825                                           *
    OSCCON=$70
    DEFINE OSC 32
    '                       PIC 16F1825
    TRISA     = %001111	   ' Make some pins Input
    trisc     = %001111  ;Make some pins Input
    ANSELA=0
    ANSELC=0
    X VAR byte
    darta   VAR byte[4]
        clear
        modout var latc.4
        darta.0[14]=1
        darta.0[15]=1
        modout =1
        lata.5=0    ;cro triger
    Main_Loop:
        lata.5=1
        modout=0
        pauseus 9900
        modout =1
        pauseus 1880
        for x = 0 to 30
            modout =0
            if  darta.0[x]  then
                pauseus 2000
                pauseus 780
            modout =1
            pauseus  635
        next
        modout =1
        lata.5=0
        PAUSE 200
    goto Main_Loop
    Aug 2003
    Did you try code I posted a month ago, or looked at it to determine it won’t work?
    It’s used in an IR remote receiver for a game controller (so has to be reliable)
    to interpret exactly the same pulse coded signal, with the timings being the only difference.
  6. #46
    No, I haven't used it, because protocol is different from IR protocol.
  7. #47
    Just tried Henrik's code, it gives error on:
    LSB VAR BitArray.LowWord
    "bad variable size modifier .lowword"
  8. #48
    Corrected the errors, to level of my knowledge. Code compiles now, but it does not do anything. Here it is:
    ;----[16F1829 Hardware Configuration]-------------------------------------------
    #IF __PROCESSOR__ = "16LF1829"
      #DEFINE MCU_FOUND 1
    cfg1 = _FOSC_INTOSC           ; INTOSC oscillator: I/O function on CLKIN pin
    cfg1&= _WDTE_OFF              ; WDT disabled
    cfg1&= _PWRTE_OFF             ; PWRT disabled
    cfg1&= _MCLRE_OFF             ; MCLR/VPP pin function is digital input
    cfg1&= _CP_OFF                ; Program memory code protection is disabled
    cfg1&= _CPD_OFF               ; Data memory code protection is disabled
    cfg1&= _BOREN_OFF             ; Brown-out Reset disabled
    cfg1&= _CLKOUTEN_OFF          ; CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
    cfg1&= _IESO_ON               ; Internal/External Switchover mode is enabled
    cfg1&= _FCMEN_OFF             ; Fail-Safe Clock Monitor is disabled
      __CONFIG _CONFIG1, cfg1
    cfg2 = _WRT_OFF               ; Write protection off
    cfg2&= _PLLEN_OFF             ; 4x PLL disabled
    cfg2&= _STVREN_ON             ; Stack Overflow or Underflow will cause a Reset
    cfg2&= _BORV_19               ; Brown-out Reset Voltage (Vbor), low trip point selected.
    cfg2&= _LVP_OFF               ; High-voltage on MCLR/VPP must be used for programming
      __CONFIG _CONFIG2, cfg2
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    DEFINE OSC 16
    include "modedefs.bas"
    ANSELA = %00000000 ' Set PORTA pins to digital I/O
    ANSELB = %00000000 ' Set PORTB pins to digital I/O
    ANSELC = %00000000 ' Set PORTC pins to digital I/O
    WPUB = %00000000   'DISABLE WEAK PULL UP
    TRISB=%11110000 'SET PORTB TO OUTPUT
    TRISA=%00000000 'SET PORTA TO OUTPUT
    TRISC=%00000000 'SET PORTC TO OUTPUT
    OSCCON = %01111111 'SET INTOSC TO 16MHZ
    ' Set LCD Data port
    DEFINE LCD_DREG PORTC
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 4
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTA
    ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 5
    ' Set LCD Enable port
    DEFINE LCD_EREG PORTA
    ' Set LCD Enable bit
    DEFINE LCD_EBIT 4
    ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    ' Set command delay time in us
    DEFINE LCD_COMMANDUS 1500
    ' Set data delay time in us
    DEFINE LCD_DATAUS 44
    LCDOUT $FE, $C0, "TEST"
    HighTime  VAR WORD
    LowTime   VAR WORD
    BitArray  VAR WORD [2]
    LSB       VAR BitArray.lowbyte
    MSB       VAR BitArray.Highbyte
    Signal var PORTB.6
    i var word
    WaitForStartBit:
      GOSUB MeasureLow
      IF (LowTime < 9500) OR (LowTime > 10500) THEN WaitForStartBit    ' 9.5-10.5ms qualifies
      GOSUB MeasureHigh
      IF (HighTime < 1500) OR (HighTime > 2500) THEN WaitForStartBit    ' 1.5-2.5ms qualifies
    NextLevel:
    For i = 0 to 31
      GOSUB MeasureLow
      IF (LowTime > 400) AND (LowTime < 800) THEN BitArray.0[i] = 1     ' 500-700us qualifies as 1
      IF (LowTime > 1700) AND (LowTime < 2320) THEN BitArray.0[i] = 0   ' 1800-2200us qualifies as 0
    NEXT
    LCDOUT $FE,$01, "HighWord", DEC MSB
    LCDOUT $FE,$C0, "LowWord", DEC LSB
    Pause 1000
    Goto WaitForStartBit
    MeasureLow:
      LowTime = 0
      While Signal = 1 : WEND         ' Wait for low level
      While Signal = 0                ' Measure low level
        LowTime = LowTime + 100       ' Resolution is 100us, change if needed
        PauseUS 92                    ' Tweak to calibrate, depends on actual loop time
      WEND
    MeasureHigh:
      HighTime = 0
      While Signal = 0 : WEND   ' Wait for low
        While Signal = 1              ' Measure high level
        HighTime = HighTime + 1       ' Resolution is 100us, change if needed
        PauseUS 92                    ' Tweal to calibrate, depends on actual loop time
      WEND
    Modified measurelow subroutine, to show the value of LowTime:
    MeasureLow:
      LowTime = 0
      WEND
      LCDOUT $FE, $C0, "T:",DEC lowtime, "  "
    It returns 600.
  10. #50
    This is quite strange, because I'm using 16F1829, running at 16mhz. DEFINE OSC is correct, I've launched series of pulses with 1ms duration, and checked by scope - all correct.
  11. #51
    Modified HighTime routine too:
    MeasureHigh:
      HighTime = 0
      WEND
      LCDOUT $FE,$c0, "T2:",DEC hightime, "  "
    it returns 9.
    Feels like MCU is operating very slow?
  12. #52
    what are you expecting to see ?
    how many times do you think 100uS will divide into a shade less than 1mS ?
    Where it should returned something like 9000, it returns 600, is not this strange?
  14. #54
    the code is expecting 10 mS pulse
    I goofed there. Since the BitArray actually consists of two WORDs and you want the least and most significant WORD of that array the declaration should read
    LSB VAR BitArray[0]
    MSB VAR BitArray[1]
    What should return 9000?
    You've changed the MeasureHigh routine so it only adds 1 each time thru a loop that (ideally) takes 100us to execute. A pulse lasting for 10ms will (ideally) cause that loop to execute 100 times, you end up with 100 in (instead of 10000) in HighTime.
    I modified henriks code an tested it with my simulation , works fine
    '*  Name    : deMODULATOR.BAS                                   *
    '*  Author  : richard's modified version of henriks             *
    '*  Notice  :  2016                                             *
    '*  Date    : 10/10/2016                                         *
    '*  Notes   : decodes missing pulse encoded data stream A.5     *
    '*          : 16F1825                                           *
    OSCCON=$70
    DEFINE OSC 32
    '                       PIC 16F1825
        TRISA     = %111110	 ' Make somepins Input
        trisc     = %111100  ;Make some pins Input
        ANSELA=0
        ANSELC=0
        led var latc.0      ;DEBUG
        led2 var latc.1      ;DEBUG
        demod var porta.5     ;demod in
        X VAR byte
        darta   VAR byte[4]
        counter var word
        dm_state   VAR byte
        lata.0=1             ;DEBUG
        clear
        led=0
        DEFINE DEBUG_REG PORTA
        DEFINE DEBUG_BIT 0
        DEFINE DEBUG_BAUD 9600
        DEFINE DEBUG_MODE 0
        pause 2000
        Debug "Start",13 ,10
        DEFINE PULSIN_MAX 9000
    HighTime  VAR WORD
    LowTime   VAR WORD
    WaitForStartBit:
        GOSUB MeasureLow
        IF (LowTime < 9500) OR (LowTime > 11000) THEN WaitForStartBit    ' 9.5-10.5ms qualifies
        led2=1
        GOSUB MeasureHigh
        led2=0
        NextLevel:
        For x = 0 to 31
            GOSUB MeasureLow
            IF     LowTime < 1000   then
                darta .0[x] = 0
                darta .0[x] = 1
        NEXT
        led=1
        Debug 13 ,10 ,bin8 darta[3],bin8 darta[2],bin8 darta[1],bin8 darta[0]    ;DEBUG
        Pause 1000
        led=0
    MeasureLow:
      LowTime = 0
      While demod = 1 : WEND         ' Wait for low level
      While demod = 0                ' Measure low level
      WEND
    MeasureHigh:
      HighTime = 0
      While demod = 0 : WEND	  ' Wait for low
        While demod = 1              ' Measure high level
        HighTime = HighTime + 100       ' Resolution is 100us, change if needed
      WEND
    for comparison I came up with this , oddly it uses mode code space
    '*  Author  : richard                                           *
    '*  Notice  : Copyright (c) 2016                                *
    '*          : 16F1825                                           *
    OSCCON=$70
    DEFINE OSC 32
    '                       PIC 16F1825
        ANSELA=0
        ANSELC=0
        X VAR byte
        darta   VAR byte[4]
        counter var word
        dm_state   VAR byte
        lata.0=1             ;DEBUG
        clear
        led=0
        DEFINE DEBUG_BIT 0
        DEFINE DEBUG_MODE 0
        pause 2000
        select case dm_state
            case 0
                PULSIN demod, 0, counter
                if counter > 7800  then
                    dm_state=1
                    x=0
            case 1
                pir1.1=0
                tmr2=0
                t2con=7
                while demod : wend
                if   pir1.1 | (tmr2 < 220)   then
                   dm_state=0
                    dm_state=2
                    tmr2=0
            case 2
                while !demod : wend
                t2con=0
                if   pir1.1 then
                 dm_state=0
                 led=1
                if tmr2 < 150    then
                    darta.0[x]=0
                    darta.0[x]=1
                tmr2=0
                x=x+1
                if x >31 then
                    dm_state=3
                    while demod : wend
                    t2con=7
            case 3
                led2=1     ;DEBUG
            '    Debug 13 ,10 ,hex2 darta[3] ,hex2 darta[2],hex2 darta[1],hex2 darta[0]    ;DEBUG
                pause 200
                led2=0             ;DEBUG
                dm_state=0
        end select
    the 1ms was just test, I used it to check MCU speed, whenever OSCCON and DEFINE OSC were correct, later it was removed.
    I have Henrik's code running, I connect it to actual hardware, and width of large pulse, which should be 9000us, measured only 600 ?
  19. #59
    I've copied all code from post #35, including timings.
    http://www.picbasic.co.uk/forum/show...165#post138165
  20. #60
    then you are doing something wrong ,plus you said in previous posts the pulse was 9900uS it makes a difference . whats correct ?
    your looking more scatterlogical than my exwife
    haha, no, I'm not blond
    Just I'm multi-tasking very hard.
    9000, 9900, it was just typo, exact timings are given on the previous page. I don't know what I'm doing wrong, since code is Henrik's. As I said, I verified MCU speed and OSC settings, and they are all correct. Pulse timings are also correct, verified using two different scopes. this is only what I can do.
  1. Is there an ICSP pinout standard???
    By OldMarty in forum General
    Last Post: - 21st September 2016, 12:29
  2. Interpret to Picbasic Code ¿?!!
    By Denner in forum PBP3
    Last Post: - 9th June 2015, 18:00
  3. sample code for AT45DB642D in Picbasic Pro
    By itsssyam in forum General
    Last Post: - 10th March 2010, 06:01
  4. Max/232 Bootloader problems - Schematic attached...
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 15:54
  5. Replies: 0
    Last Post: - 30th November 2004, 02:18
