Is it possible to interpret non-standard serial data with PicBasic (sample attached)
Results 1 to 40 of 61
    Aug 2003
    Default Re: Is it possible to interpret non-standard serial data with PicBasic (sample attach
    Did you try code I posted a month ago, or looked at it to determine it won’t work?
    It’s used in an IR remote receiver for a game controller (so has to be reliable)
    to interpret exactly the same pulse coded signal, with the timings being the only difference.
    No, I haven't used it, because protocol is different from IR protocol.
    Just tried Henrik's code, it gives error on:
    LSB VAR BitArray.LowWord
    "bad variable size modifier .lowword"
    Corrected the errors, to level of my knowledge. Code compiles now, but it does not do anything. Here it is:
    ;----[16F1829 Hardware Configuration]-------------------------------------------
    #IF __PROCESSOR__ = "16LF1829"
      #DEFINE MCU_FOUND 1
    cfg1 = _FOSC_INTOSC           ; INTOSC oscillator: I/O function on CLKIN pin
    cfg1&= _WDTE_OFF              ; WDT disabled
    cfg1&= _PWRTE_OFF             ; PWRT disabled
    cfg1&= _MCLRE_OFF             ; MCLR/VPP pin function is digital input
    cfg1&= _CP_OFF                ; Program memory code protection is disabled
    cfg1&= _CPD_OFF               ; Data memory code protection is disabled
    cfg1&= _BOREN_OFF             ; Brown-out Reset disabled
    cfg1&= _CLKOUTEN_OFF          ; CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
    cfg1&= _IESO_ON               ; Internal/External Switchover mode is enabled
    cfg1&= _FCMEN_OFF             ; Fail-Safe Clock Monitor is disabled
      __CONFIG _CONFIG1, cfg1
    cfg2 = _WRT_OFF               ; Write protection off
    cfg2&= _PLLEN_OFF             ; 4x PLL disabled
    cfg2&= _STVREN_ON             ; Stack Overflow or Underflow will cause a Reset
    cfg2&= _BORV_19               ; Brown-out Reset Voltage (Vbor), low trip point selected.
    cfg2&= _LVP_OFF               ; High-voltage on MCLR/VPP must be used for programming
      __CONFIG _CONFIG2, cfg2
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    DEFINE OSC 16
    include "modedefs.bas"
    ANSELA = %00000000 ' Set PORTA pins to digital I/O
    ANSELB = %00000000 ' Set PORTB pins to digital I/O
    ANSELC = %00000000 ' Set PORTC pins to digital I/O
    WPUB = %00000000   'DISABLE WEAK PULL UP
    TRISB=%11110000 'SET PORTB TO OUTPUT
    TRISA=%00000000 'SET PORTA TO OUTPUT
    TRISC=%00000000 'SET PORTC TO OUTPUT
    OSCCON = %01111111 'SET INTOSC TO 16MHZ
    ' Set LCD Data port
    DEFINE LCD_DREG PORTC
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 4
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTA
    ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 5
    ' Set LCD Enable port
    DEFINE LCD_EREG PORTA
    ' Set LCD Enable bit
    DEFINE LCD_EBIT 4
    ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    ' Set command delay time in us
    DEFINE LCD_COMMANDUS 1500
    ' Set data delay time in us
    DEFINE LCD_DATAUS 44
    LCDOUT $FE, $C0, "TEST"
    HighTime  VAR WORD
    LowTime   VAR WORD
    BitArray  VAR WORD [2]
    LSB       VAR BitArray.lowbyte
    MSB       VAR BitArray.Highbyte
    Signal var PORTB.6
    i var word
    WaitForStartBit:
      GOSUB MeasureLow
      IF (LowTime < 9500) OR (LowTime > 10500) THEN WaitForStartBit    ' 9.5-10.5ms qualifies
      GOSUB MeasureHigh
      IF (HighTime < 1500) OR (HighTime > 2500) THEN WaitForStartBit    ' 1.5-2.5ms qualifies
    NextLevel:
    For i = 0 to 31
      GOSUB MeasureLow
      IF (LowTime > 400) AND (LowTime < 800) THEN BitArray.0[i] = 1     ' 500-700us qualifies as 1
      IF (LowTime > 1700) AND (LowTime < 2320) THEN BitArray.0[i] = 0   ' 1800-2200us qualifies as 0
    NEXT
    LCDOUT $FE,$01, "HighWord", DEC MSB
    LCDOUT $FE,$C0, "LowWord", DEC LSB
    Pause 1000
    Goto WaitForStartBit
    MeasureLow:
      LowTime = 0
      While Signal = 1 : WEND         ' Wait for low level
      While Signal = 0                ' Measure low level
        LowTime = LowTime + 100       ' Resolution is 100us, change if needed
        PauseUS 92                    ' Tweak to calibrate, depends on actual loop time
      WEND
    MeasureHigh:
      HighTime = 0
      While Signal = 0 : WEND   ' Wait for low
        While Signal = 1              ' Measure high level
        HighTime = HighTime + 1       ' Resolution is 100us, change if needed
        PauseUS 92                    ' Tweal to calibrate, depends on actual loop time
      WEND
    Modified measurelow subroutine, to show the value of LowTime:
    MeasureLow:
      LowTime = 0
      WEND
      LCDOUT $FE, $C0, "T:",DEC lowtime, "  "
    It returns 600.
    This is quite strange, because I'm using 16F1829, running at 16mhz. DEFINE OSC is correct, I've launched series of pulses with 1ms duration, and checked by scope - all correct.
    Modified HighTime routine too:
    MeasureHigh:
      HighTime = 0
      WEND
      LCDOUT $FE,$c0, "T2:",DEC hightime, "  "
    it returns 9.
    Feels like MCU is operating very slow?
    what are you expecting to see ?
    how many times do you think 100uS will divide into a shade less than 1mS ?
  1. Is there an ICSP pinout standard???
    By OldMarty in forum General
    Last Post: - 21st September 2016, 13:29
  2. Interpret to Picbasic Code ¿?!!
    By Denner in forum PBP3
    Last Post: - 9th June 2015, 19:00
  3. sample code for AT45DB642D in Picbasic Pro
    By itsssyam in forum General
    Last Post: - 10th March 2010, 07:01
  4. Max/232 Bootloader problems - Schematic attached...
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 16:54
  5. Replies: 0
    Last Post: - 30th November 2004, 03:18
