Is it possible to interpret non-standard serial data with PicBasic (sample attached)
Results 1 to 40 of 61
    Post Re: Is it possible to interpret non-standard serial data with PicBasic (sample attach
    as close as I can get . it has a glitch after the last bit sent
    '*  Name    : MODULATOR.BAS                                     *
    '*  Notice  : Copyright (c) 2016 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 5/29/2016                                         *
    '*  Notes   :                        *
    '*          : 16F1825                                           *
                 __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_ON  &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
                  __config      _CONFIG2, _PLLEN_OFF & _LVP_OFF
    OSCCON=$70
    DEFINE OSC 8
    '                       PIC 16F1825
    TRISA     = %011111    '
    trisc     = %001111  ;
    ANSELA=0
    ANSELC=0
    MDSRC=    %00000000
    MDCARH   =%01000100
    MDCARL   =%00000000
    X VAR byte
    darta   VAR byte[4]
    TIMER1     VAR WORD EXT
    clear
    modout var latc.4
    darta.0[14]=1
    darta.0[15]=1
    t2con=6
    pr2=158
    CCPR1L =318>>2
    ccp1con=12
    MDCON.0 = 0
    modout =1
    Main_Loop:
    lata.5=1 ; cro trigger
    while !pir1.1 :wend
    modout=0
    pauseus 9900
    modout =1
    pir1.1=0
    while !pir1.1 :wend
    pir1.1=0
    while !pir1.1 :wend
    MDCON=    %11000001
    pir1.1=0
    while !pir1.1 :wend
    for x = 0 to 31
    if  darta.0[x]  then
    MDCON.0 = 0
    pir1.1=0
    while !pir1.1 :wend
    pir1.1=0
    while !pir1.1 :wend
    MDCON.0 = 1
    pir1.1=0
    while !pir1.1 :wend
    MDCON.0 = 1
    pir1.1=0
    while !pir1.1  :wend
    next
    modout = 1
    MDCON = 0
    lata.5=0
    PAUSE 200
    goto Main_Loop
    Default Re: Is it possible to interpret non-standard serial data with PicBasic (sample attach
    Thanks!
    I guess, your code can run on 16F1829 ?
    should do they are the same except for a few extra pins
  1. Is there an ICSP pinout standard???
    By OldMarty in forum General
    Last Post: - 21st September 2016, 13:29
  2. Interpret to Picbasic Code ¿?!!
    By Denner in forum PBP3
    Last Post: - 9th June 2015, 19:00
  3. sample code for AT45DB642D in Picbasic Pro
    By itsssyam in forum General
    Last Post: - 10th March 2010, 07:01
  4. Max/232 Bootloader problems - Schematic attached...
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 16:54
  5. Replies: 0
    Last Post: - 30th November 2004, 03:18
