Is it possible to interpret non-standard serial data with PicBasic (sample attached)
Results 1 to 40 of 61
    Default Re: Is it possible to interpret non-standard serial data with PicBasic (sample attach
    Indeed, but lack of knowledge....
    Code that works - It differentiates "0" from any other command:
    UIDEDA:
    if pulsi=0 then
    FOR N=0 TO 300     'main loop duration
    IF PULSI=0 THEN
    A=A+c                                 'count positive edges
    c=0   'stop increasing  1 after first loop
    d=1    'set increase for 0
    B=B+d         'count 0 volt
    d=0     'stop increasing 0 after first loop
    c=1      'set increase for 1
    NEXT
    IF A<>0 AND B<>0 THEN
    lcdout $FE,2, "A=",#A, "    "
    lcdout $FE,$C0,"B=",#B, "    "
    if a=7 and b=8 then high natura    'on
    if a=6 and b=7 then low natura   'off
    A=0
    B=0
    GOTO UIDEDA
    Now I want to ad an array, where, when "1" occurs, value of N variable will be stored, which later can be counted, and position of "1" s and "0" -s detected.
    Going totally crazy, can't figure out what to do and how
    Logically, code should look like this:
    WAIT FOR LOW LEVEL AND MEASURE IT'S DURATION
    IF LOW LEVEL LENGTH=10MS THEN MEASURE HIGH LEVEL DURATION AFTER IT
    IF HIGH LEVEL DURATION WAS 2MS, THEN GO TO NEXT STEP, ELSE, LOOP THIS CYCLE AGAIN
    NEXT LEVEL:
    CONSIDER 600US LOW LEVEL AS 1, AND 2MS LOW LEVEL AS 0, WRITE THEM SEQUENTALY TO 32 BIT ARRAY, UNTIL 32 BITS WRITTEN
    EXTRACT MSB AND LSB FROM ARRAY
    CONVERT TO WORD
    Or, more "programmer" approach. Assuming "A" is the input pin:
    START COUNTING
    A=0, B=0
    WHILE A=1, B=B+1
    WHILE A=0, C=C+1
    IF B=500 AND C=100 THEN CONTINUE, ELSE, START OVER
    B=0 C=0
    FOR N=1 TO 32
    WHILE A=1, B=B+1
    WHILE A=0, C=C+1
    IF B=50 AND C=50 THEN CONTENTS[N]=1
    IF B=50 AND C=150 THEN CONTENTS[N]=0
    A=0, B=0
    NEXT N
    Here's one idea:
    HighTime  VAR WORD
    LowTime   VAR WORD
    BitArray  VAR WORD [2]
    LSB       VAR BitArray.LowWord
    MSB       VAR BitArrat.HighWord
    WaitForStartBit:
      GOSUB MeasureLow
      IF (LowTime < 9500) OR (LowTime > 10500) THEN WaitForStartBit    ' 9.5-10.5ms qualifies
      GOSUB MeasureHigh
      IF (HighTime < 1500) OR (HighTime > 2500) THEN WaitForStartBit    ' 1.5-2.5ms qualifies
    NextLevel:
    For i = 0 to 31
      GOSUB MeasureLow
      IF (LowTime > 400) AND (LowTime < 800) THEN BitArray.0[i] = 1     ' 500-700us qualifies as 1
      IF (LowTime > 1700) AND (LowTime < 2320) THEN BitArray.0[i] = 0   ' 1800-2200us qualifies as 0
    NEXT
    LCDOUT $FE,$01, "HighWord", DEC MSB
    LCDOUT $FE,$C0, "LowWord", DEC LCB
    Pause 1000
    Goto WaitForStartBit
    MeasureLow:
      LowTime = 0
      While Signal = 1 : WEND         ' Wait for low level
      While Signal = 0                ' Measure low level
        LowTime = LowTime + 100       ' Resolution is 100us, change if needed
        PauseUS 92                    ' Tweak to calibrate, depends on actual loop time
      WEND
    MeasureHigh:
      HighTime = 0
      WhileSignal = 0 : WEND	  ' Wait for low
        While Signal = 1              ' Measure high level
        HighTime = HighTime + 1       ' Resolution is 100us, change if needed
        PauseUS 92                    ' Tweal to calibrate, depends on actual loop time
      WEND
    I can't compile this let alone test it but it serves to show the genereal idea of a software only solution.
    Thanks, will give it a try tomorrow.
    My oscilloscope can record in .csv format, is it possible in some emulator to "play back" this recording, and feed it to virtual chip? So I can test and debug without using original hardware, which generates these pulses.
  1. Is there an ICSP pinout standard???
    By OldMarty in forum General
    Last Post: - 21st September 2016, 13:29
  2. Interpret to Picbasic Code ¿?!!
    By Denner in forum PBP3
    Last Post: - 9th June 2015, 19:00
  3. sample code for AT45DB642D in Picbasic Pro
    By itsssyam in forum General
    Last Post: - 10th March 2010, 07:01
  4. Max/232 Bootloader problems - Schematic attached...
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 16:54
  5. Replies: 0
    Last Post: - 30th November 2004, 03:18
