PIC18F I2C Communication with Arduino
Results 1 to 12 of 12
    May 2016
    Default PIC18F I2C Communication with Arduino
    Hello all,
    I read all the I2C related posts but still can't fully understand how to send dada from PIC18F to an Arduino.
    I set the address of arduino to 0x26 and try to do following in PicBasic but I don't get any data:
    TRISC.0 = 0
    TRISB = 000000
    LED VAR PORTC.0   ' Assign name "LED" to PORTC.0
    SCL VAR PORTB.3    ' Clock pin
    SDA VAR PORTB.1    ' Data pin
    ADDR VAR WORD
    ADDR = $26 ' I2C address
    mainloop:
       HIGH LED        ' Turn on LED connected to PORTB.0
       Pause 1000       ' Delay for 1 seconds
       I2CWrite SDA,SCL,ADDR,[0]
       LOW LED          ' Turn off LED connected to PORTB.0
       Goto mainloop   ' Go back to loop and blink LED forever
    Any idea?
    Oct 2009
    Default Re: PIC18F I2C Communication with Arduino
    Im no expert, but don't you have to send data. All the examples I've seen, and use send and receive a variable after the address, eg to send the value of a word variable
    I2CWRITE SDApin,SCLpin,i2cWriteAddress,i2cControl,[variable.lowbyte,variable.highbyte]
    I can't see that in your code
    Also I think you need to set one device as a slave and another as master, so maybe posting your arduino code could also help those more qualified to comment to asses whats going on
    The data being sent is the value 0, that looks alright to me though I've literally never used I2CWrite.
    Check the pins you're using for multiplexed functions, specifically analog such as ADC and comparators and make sure the pins are set to digital.
    Then I'd check the pins with a scope or logic analyzer to verify if data is actually coming out or not - if you don't KNOW, for sure, that the Arduino code is working.
    Really Henrick? Wow, I use it all the time to write to serial eeprom's, a/d's and i/o expanders, etc. You should really design more hardware..
    EN82fn
    Oct 2009
    Can you inform us which 18F pic you are using?
    Most of the 18F PICs (28 pin and 40 pin) have the hardware I2C pins on PORT C not PORTB. Whilst I'm sure PBP can define any pins, it might be "better" to use the actual pins associated with the hardware module on the PIC, eg
    SCLpin             var PORTC.3          'clk
    SDApin             var PORTC.4          'data
    May 2016
    I am using PIC18F2450 which doesn't have hardware I2C pins.Isn't I2CWRITE just a software solution and not using actual hardware?
    here is arduino code:
    #include <Wire.h>
    void setup() {
      Wire.begin(0x26);                // join i2c bus with address
      Wire.onReceive(receiveEvent);
      Serial.begin(9600);
    void loop() {
     delay(1000);
    void receiveEvent(int howMany) {
      while (1 < Wire.available()) {
        char c = Wire.read();
        Serial.print(c);
      int x = Wire.read();
      Serial.println(x);
  1. Interfacing with Arduino I2C LCD
    By norohs in forum Documentation
    Last Post: - 30th May 2017, 19:53
  2. I2C lcd ( arduino ) with PICBASIC, help
    Last Post: - 10th September 2014, 19:00
  3. EEprom and MCP9801 I2C communication problems
    By aajgss in forum mel PIC BASIC Pro
    Last Post: - 3rd September 2011, 22:45
  4. How do I operate an Arduino I2C LCD
    By menta in forum General
    Last Post: - 13th July 2011, 03:28
  5. Replies: 2
    Last Post: - 10th June 2005, 03:34
