Bootloader pic16f1825 @32mhz pll
Results 1 to 11 of 11
    Default Bootloader pic16f1825 @32mhz pll
    MY bootloader config.ini is as follows but I cannot get it to work . in fact pll and bootloader seems to always give me grief
    any ideas ?
    ; optional path information - default output folder is
    ; user documents -> umcbuild...
    [PATH]
    Output=C:\MYBOOTLOADER
    [TEMPLATE]
    ;PIC18=..\src\18F\umc_loader.asm
    PIC16=..\src\16F\umc_loader.asm
    ; device name and OSC...
    [MCU]
    Device=16F1825
    OSC=32000000
    ;[USART]
    BAUDRATE = 19200 ; initial startup baudrate (default is 19200)
    BRGH16 = 1 ; 16 bit SPBRG support (default is OFF)
    ; device configuration settings...
    [CONFIG] ;----- CONFIG1 Options --------------------------------------------------
    __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_ON  &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
    ; place startup code in here...
    [USERCODE]
    ;banksel APFCON0
    ; you need this as APFCON0 is at banked address.
    ;bSf APFCON0,7 ;bSf APFCON0,2
    banksel ANSELC ; you need this as ANSELA is at banked address.
    clrf ANSELC
    banksel OSCCON ; you need this as OSCCON is at banked address.
    movlw 0xf0 ; 8 mhz, pll enabled
    movwf OSCCON
    banksel OSCSTAT
    btfss OSCSTAT,6
    goto $-1
    Aug 2011
    Default Re: Bootloader pic16f1825 @32mhz pll
    I don't have a chip to try it on, but off the top of my head that looks ok.
    Are you sure it's not the _config _WDTEN_ON that's fouling things up?
    Try _WDTEN_OFF or _WDTE_SWDTEN (if you want it programmable) and see what happens.
    didn't help
    last effort
    [PATH]
    [TEMPLATE]
    [MCU]
    Device=16F1825
    OSC=8000000
    [USART]
     __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_OFF  &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
     __config      _CONFIG2, _PLLEN_OFF & _LVP_OFF
    [USERCODE]
    ;banksel APFCON0
    ; bCf APFCON0,7
    ; bCf APFCON0,2
    ; banksel ANSELC ; you need this as ANSELA is at banked address.
     movlb 3
     BCF ANSELC,5
     BCF ANSELC,4
     movlb 1
     BSF TRISC,4
     BSF TRISC,5
     ;movlb 1
     movlw 0x70 ; 8 MHz
     movwf OSCCON
    ; btfss OSCSTAT,6
    ; goto $-1
    The attached is what I use when using the ccp on portc. It places com on porta.
    EN82fn
    tried that dave , still no go
    query this though I say It places com on portc
    banksel APFCON0 ; you need this as APFCON0 is at banked address.
    movlw b'00000000' ; ALL PORTS TO DEFAULT
    ;movlw b'10000100' ; COM PORT TO RA0:RA1
    movwf APFCON0
    not sure where i'm going wrong
    You are right Richard, I had the wrong file on the wrong computer. Try this one. I really need to watch what I'm doing....
    EN82fn
  1. Pic16f1825 adcon0
    By nobner in forum mel PIC BASIC Pro
    Last Post: - 19th May 2014, 09:41
  2. PIC16F1825 unable to Light an LED
    By Lestat in forum mel PIC BASIC Pro
    Last Post: - 16th March 2013, 18:38
  3. Replies: 5
    Last Post: - 10th April 2011, 12:48
  4. Using INTOSC 32Mhz as RF Radio Control and Data Communication
    By rayzrocket in forum mel PIC BASIC Pro
    Last Post: - 13th January 2011, 12:10
  5. Hs Pll
    By Ron Marcus in forum Off Topic
    Last Post: - 21st February 2006, 00:34
