Bootloader pic16f1825 @32mhz pll
Results 1 to 11 of 11
    Default Bootloader pic16f1825 @32mhz pll
    MY bootloader config.ini is as follows but I cannot get it to work . in fact pll and bootloader seems to always give me grief
    any ideas ?
    ; optional path information - default output folder is
    ; user documents -> umcbuild...
    [PATH]
    Output=C:\MYBOOTLOADER
    [TEMPLATE]
    ;PIC18=..\src\18F\umc_loader.asm
    PIC16=..\src\16F\umc_loader.asm
    ; device name and OSC...
    [MCU]
    Device=16F1825
    OSC=32000000
    ;[USART]
    BAUDRATE = 19200 ; initial startup baudrate (default is 19200)
    BRGH16 = 1 ; 16 bit SPBRG support (default is OFF)
    ; device configuration settings...
    [CONFIG] ;----- CONFIG1 Options --------------------------------------------------
    __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_ON  &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
    ; place startup code in here...
    [USERCODE]
    ;banksel APFCON0
    ; you need this as APFCON0 is at banked address.
    ;bSf APFCON0,7 ;bSf APFCON0,2
    banksel ANSELC ; you need this as ANSELA is at banked address.
    clrf ANSELC
    banksel OSCCON ; you need this as OSCCON is at banked address.
    movlw 0xf0 ; 8 mhz, pll enabled
    movwf OSCCON
    banksel OSCSTAT
    btfss OSCSTAT,6
    goto $-1
    Aug 2011
    Default Re: Bootloader pic16f1825 @32mhz pll
    I don't have a chip to try it on, but off the top of my head that looks ok.
    Are you sure it's not the _config _WDTEN_ON that's fouling things up?
    Try _WDTEN_OFF or _WDTE_SWDTEN (if you want it programmable) and see what happens.
    didn't help
    last effort
    [PATH]
    [TEMPLATE]
    [MCU]
    Device=16F1825
    OSC=8000000
    [USART]
     __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_OFF  &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
     __config      _CONFIG2, _PLLEN_OFF & _LVP_OFF
    [USERCODE]
    ;banksel APFCON0
    ; bCf APFCON0,7
    ; bCf APFCON0,2
    ; banksel ANSELC ; you need this as ANSELA is at banked address.
     movlb 3
     BCF ANSELC,5
     BCF ANSELC,4
     movlb 1
     BSF TRISC,4
     BSF TRISC,5
     ;movlb 1
     movlw 0x70 ; 8 MHz
     movwf OSCCON
    ; btfss OSCSTAT,6
    ; goto $-1
    The attached is what I use when using the ccp on portc. It places com on porta.
    EN82fn
    tried that dave , still no go
    query this though I say It places com on portc
    banksel APFCON0 ; you need this as APFCON0 is at banked address.
    movlw b'00000000' ; ALL PORTS TO DEFAULT
    ;movlw b'10000100' ; COM PORT TO RA0:RA1
    movwf APFCON0
    not sure where i'm going wrong
    You are right Richard, I had the wrong file on the wrong computer. Try this one. I really need to watch what I'm doing....
    EN82fn
    Many thanks dave , that's got it going.
    bootloader confusion
    take this pgm
    '*  Name    :blinky.pbp                                        *
    '*  Author  : richard                                   *
    '*  Notice  :                                *
    '*  Date    :                                          *
    '*  Version :    16f1825     @3.3 volts                               *
    '*  Notes   :       *
    DEFINE LOADER_USED 1
    DEFINE OSC 32
    DEFINE HSER_SPBRG 207  ' 38400 Baud @ 32MHz,
    SPBRGH = 0
    led var latc.0
    TRISA=%111111
    TRISC=%111110
    OSCCON=$F0
    ANSELA=0
    ANSELC=0
    while !OSCSTAT.6
    wend
    hserout [ "Ready",9,"%",bin6 trisc,13,10]
    mainloop:
    led=!led
    goto mainloop
    when loaded with pk2
    printout
    Ready %111110
    when loaded with bootloader
    Ready %111110
    ie all portc is input except bit 0, yet hserout works tx=portc.4
    data sheet says
    Setting the TXEN bit of the TXSTA register enables the
    transmitter circuitry of the EUSART. Clearing the SYNC
    bit of the TXSTA register configures the EUSART for
    asynchronous operation. Setting the SPEN bit of the
    RCSTA register enables the EUSART and automatically
    configures the TX/CK I/O pin as an output. If the TX/CK
    pin is shared with an analog peripheral, the analog I/O
    function must be disabled by clearing the corresponding
    ANSEL bit.
    all is good
    yet for the bootloader
    [PATH]
    [TEMPLATE]
    [MCU]
    Device=16F1825
    OSC=32000000
    [USART]
    [USERCODE]
     movlb 3
     BCF ANSELC,5
     BCF ANSELC,4
     movlb 1
     BCF TRISC,4       without this bootloader fails
     BSF TRISC,5
     movlw 0x70 ; 32 MHz
     movwf OSCCON
     btfss OSCSTAT,6
     goto $-1
    I just don't follow it
    Richard, The HSEROUT command is probably setting the tris register for the operator to make things easy. I do not use any of the serial commands available with PBP. I only use the hardware serial ports and use interrupt driven serial input as well as output. Also during the Boot Loading process you have to set all port direction registers and APFCON registers as your PBP code is not executing yet. Also clearing bits 4:5 of ANSELC does no good as they are not inplemented. No analog operation of these pins.
    EN82fn
    No it seems not , I have done a bit more experimenting and the chip works as per the data sheet ie
    seting or clearing the tris bit has no effect on the eusart ,
    this int driven background printing demo works just fine when trisc.4 is set or not
    clearing bits 4:5 of ANSELC does no good as they are not implemented
    correct , that saves a couple of words (don't know how I missed that ) and what you say about APFCON makes sense if it can affect the bootloader
    '*  Name    : PRINT_16_TX_INT.pbp                                *
    '*  Notice  :                                *
    '*  Date    :                                          *
    '*  Version :    16f1825                                   *
    '*  Notes   :       *
    DEFINE OSC 32
    include "dt_ints-14.bas"
    include "REENTERPBP.bas"
    asm
    INT_LIST macro
           INT_HANDLER TX_INT  , _do_tx, PBP,no
          INT_CREATE
    RCSTA = $90   ' Enable serial port & continuous receive
    TXSTA = $20   ' Enable transmit, BRGH = 0
    SPBRG = 51    ' 38400 Baud @ 32MHz, 0.16%
    SPBRGH = 0
    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
    prnb var byte[32] bank0
    spos var byte bank0
    rpos var byte bank0
    maxq con 31
    HEAD VAR BYTE [70]
    I VAR BYTE
    J VAR BYTE
    K VAR BYTE
    PASS VAR WORD
    led var latc.0
    TRISA=%111111
    TRISC=%111110
    OSCCON=$f0
    ANSELA=0
    ANSELC=0
    CLEAR
    while !OSCSTAT.6
    wend
    LED=0
    INTCON=$C0
    ARRAYWRITE head, [ "Ready",9,"%",bin6 trisc,13,10,0]
    GOSUB MYPRINT
    ARRAYWRITE head,  [ "still",9,"%",bin6 trisc,13,10,0]
    GOSUB MYPRINT
    mainloop:
    ARRAYWRITE head,  [ "still Enable 16 bit baudrate generator ",0]
    GOSUB MYPRINT
    ARRAYWRITE head,  [ "PASS Enable 16 bit baudrate generator",9,#PASS,13,10,0]
    GOSUB MYPRINT
    PASS=PASS+1
    goto mainloop
    MYPRINT:
        J=0
        WHILE HEAD[J]
            INTCON=0
            I=SPOS+1
            K=RPOS
            IF ((I)==K) || ((I== MAXQ )&& !K )  THEN
                INTCON=$C0
                PAUSE 20
                led=!led
            PRNB[SPOS]= HEAD[J]
            SPOS=SPOS+1
            PIE1.4=1
            IF SPOS=MAXQ THEN SPOS=0
            J=J+1
            INTCON=$C0
        WEND
    :do_tx
      IF  RPOS == SPOS THEN
          PIE1.4=0
          IF  PRNB[RPOS] THEN
            TXREG=PRNB[RPOS]
            RPOS=RPOS+1
            if rpos==maxQ then rpos=0
     @ INT_RETURN
    Good Job Richard....
    EN82fn
  1. Pic16f1825 adcon0
    By nobner in forum mel PIC BASIC Pro
    Last Post: - 19th May 2014, 09:41
  2. PIC16F1825 unable to Light an LED
    By Lestat in forum mel PIC BASIC Pro
    Last Post: - 16th March 2013, 18:38
  3. Replies: 5
    Last Post: - 10th April 2011, 12:48
  4. Using INTOSC 32Mhz as RF Radio Control and Data Communication
    By rayzrocket in forum mel PIC BASIC Pro
    Last Post: - 13th January 2011, 12:10
  5. Hs Pll
    By Ron Marcus in forum Off Topic
    Last Post: - 21st February 2006, 00:34
