bit order inverting
Results 1 to 5 of 5
    Macgman2000's Avatar
    Macgman2000 Guest
    Question bit order inverting
    Hello,
    What is the quickest way to invert the order of bits in an 8bit register? Currently I have data that is essentially backwards in order...IE, LSB is in the MSB poisition and MSB is in the LSB position.....
    TempVar = 11011010, I want to flip it to this FinalVar= 01011011
    Best Regards,
    Nick
    in a loop.. well i guess.
    for BitToShift=0 to 7
        FinalVar.0[7-BitToShift]=InitialVar.0[BitToShift]
        next
    There's probably a tons of way but this is the first who comes..
    Dec 2003
    Wichita KS
    Hello Nick,
    Nick
    First off:
    to invert the bits you subtract from 255
    TembVar=255-TembVar
    11011010 would become 00100101
    Second off:
    Your example is NOT a switch of LSB/MSB
    11011010 would be 10101101
    The Rev command could be used.... you would reverse bits.
    (right out of the manual)
    B0 = %10101100 REV 4 (You would use 8)
    Your example shows this... Is this what you want?
    Edit: (I notice Steve and I were looking at the exact same forum thread in which we were playing with reversing strings....) Steve you is fast!
    DWayne
    Ability to Fly:
    Pilots that are Flying:
    Wink
    Dwayne...you're not only hearing impaired, your blind too ROFL... just kidding
    Bit7 will be Bit0 and so on
    Quote Originally Posted by Dwayne
    Sometime i just sit in the Who's online and look what's happening... no secret
    BUT Yeah you're right REV will do the job. I never used it before 'cause i never had to swap bits. YEAH STEVE RTFM!!!
    I post this picture for me...
    Macgman2000 Guest
    Default bit order inverting
    Actually I clocked in data to a Temp Variable. The data came in lsb first. So in actuality I want the mirror image of the bit order. Example:
    TempVar=11000001....this was shifted in lsb first, 8x so lsb is now in msb position.
    I want it to be msb in msb position......FinalVar=10000011. I will try out your suggestion. Thanks!
    Best Regards,
    Nick
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 10:02
  2. Bits, Bytes Words and Arrays
    Last Post: - 14th June 2016, 08:55
  3. Doubt with interrupt on change
    By lugo.p in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 16:22
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
