I need to play with Nibbles, am i on the right track?
Results 1 to 5 of 5
    Jun 2016
    Melbourne, Australia
    Default Re: I need to play with Nibbles, am i on the right track?
    oh, i may have answered my own question now.....
    Since working with 8bit bytes etc, maybe is should just isolate my variables?
    something like
    LO_nibble = PortB & %00001111, for READING LSB data into LO_nibble
    or,
    HI_nibble = PortB & %11110000, for READING MSB data into HI_nibble
    and then
    PortB = LO_nibble & %00001111, for WRITING LSB data to PortB (output pins)
    or,
    PortB = LO_nibble & %11110000, for WRITING MSB data to PortB (output pins)
    Sorry, i haven't wired this idea up yet, so i can't prove my theory until i put something together on the bench.
    Marty.
    Sep 2009
    This line
    Will set bits 4-7 to 0. So it will corrupt high nibble.
    You can use this
    PORTB=(PORTB & %11110000) | (LO_nibble & %00001111)
    But this will cause RMW issue if there is any capacitive load on pins or if slew rate is limited.
    There is workaround that, your port is set to output. So there is no need to read state from PORTB.
    If you are using 18F then use LATB register.
    Or for all PIC declare another variable eg PortBState.
    And change state of individual bits in PortBState, and after then write that value to PORTB.
    PortBState var byte
    PortBState =(PortBState & %11110000) | (LO_nibble & %00001111)
    PORTB=PortBState
    For high nibble
    PortBState =(PortBState & %00001111) | (HI_nibble & %11110000)
    PORTB=PortBState
    But from your example HI_nibble=11 won't do anything. Because hi nibble of port is reference to high nibble of variable.
    If you want to reference hi nibble of port to low nibble of byte then shift value to left.
    PortBState =(PortBState & %00001111) | ((HI_nibble<<4) & %11110000)
    PORTB=PortBState
    Jun 2016
    Hmmm, i'll need to read all that a few times to sink in lol
    Basically, i have 4 variables i'm using, but i'm only using data in the LSB of each variable, so the values only range from $00 to $0F, technically i'm only using the LSB value of 0 to F within the code.
    I'm currently using(wasting) 4 ports, but only using 1/2 of the port to wire to external LEDs. my code and concept works, but now i'm trying to clean it all up by placing all 4 nibbles across only 2 8bit ports, freeing up the other 2 ports for more I/O pins etc.
    At all times, i need to only send info to each 1/2 of a given port WITHOUT corupting or moving bits on the other 1/2 of the port.
    Just looking to find a clean way to achieve this.
    Marty.
    Sep 2009
    If that is case, then try this
    Create subroutine to set 2 ports like this:
    UpdateLed:
    PORTB= ((HI_nibbleB<<4) & %11110000) | (LO_nibbleB & %00001111)
    PORTC= ((HI_nibbleC<<4) & %11110000) | (LO_nibbleC & %00001111)
    Do what ever in main loop update variables and then CALL UpdateLed, and that is all.
  1. Play & Record PWM audio?
    By Art in forum General
    Last Post: - 12th April 2015, 11:45
  2. Play with LCD on PICDEM
  3. Play Music (MP3, WAV,...) for greeting card
    Last Post: - 10th January 2007, 15:14
  4. MagCard reader (track 2 & 3)
    By odd7 in forum mel PIC BASIC Pro
    Last Post: - 25th November 2006, 13:28
  5. Word to nibbles
    By Gauge Guy in forum mel PIC BASIC Pro
    Last Post: - 11th September 2005, 04:08
