Is there an ICSP pinout standard???
Results 1 to 13 of 13
    Jun 2016
    Melbourne, Australia
    Default Re: Is there an ICSP pinout standard???
    Thanks Sheldon, makes perfect sense.
    Yes, i had no intention of using the VCC to provide power to the chip, so i was down to 4 pins myself ;-)
    I guess i can use an indexed 4pin header so there's no chance of reversal, as opposed to a naked S.I.L header which can be a 50/50 chance of getting it right ;-(
    Marty.
    Sep 2009
    I use 5 pin, so PIC Kit can be directly plugged in. And one of advantage of using 5 pin is that ground is in middle, so even if you reverse connector there is no reverse polarity.
    ditto for 5 pin
    Jun 2016
    I'd be concerned about potentially driving 13volts/Mclr onto the PGC/D pin if the 5pin header was reversed ;-(
    I think the ultimate solution for a non-keyed connector would be using an 8pin socket, wiring the pins with opposing pairs of signals so a backwards fitted header would still be correct signals into the PIC.
    e.g.
    pins:
    1 - GND
    2 - PGC
    3 - PGD
    4 - VPP/Mclr
    5 - VPP/Mclr
    6 - PGD
    7 - PGC
    8 - GND
    For me, i think i'll settle for a 4 pin KEYED header plug/socket. ;-)
    can't happen with pk2 or pk3 those devices always ident chip and test voltage levels before pgm activity takes place
    Sep 2009
    Even if it try, current is low, and PIC esd diode should clamp max voltage on pin to Vdd+0.3V. So nothing to worry.
    Aug 2011
    Even if you're not going to power the chip via ICSP it's important to provide the VDD connection.
    That way the programmer can detect the target voltage, and for some programmers like the PK3 it uses that
    target voltage to control the output voltage of the ICSPCLK and ICSPDAT signals.
    This is esp. important if you work at lower voltages.
    Sep 2009
    You can set PK3 to supply same voltage as system, so pgd/pgc voltage should be OK. But again, 5 way pin header worked for me many years, so I don't see problem with that.
    Recently I had small board with weird shape, and there was no room for 5 pin in row.
    So I tried this
    http://www.microchip.com/Development...tNO=TC2030-MCP
    It is ok.
  1. pinout or datasheet
    By RJLsystems in forum General
    Last Post: - 28th October 2014, 02:45
  2. 16F88 pinout question
    By DanPBP in forum Off Topic
    Last Post: - 13th January 2014, 03:51
  3. serin/hserin fail when i break the standard...
    By f_lez in forum mel PIC BASIC Pro
    Last Post: - 5th April 2010, 11:31
  4. Variable to Pinout conversion
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 15th April 2005, 11:14
  5. Replies: 0
    Last Post: - 30th November 2004, 03:18
