How to use include files?
Results 1 to 16 of 16
    Default How to use include files?
    I would like to try some of the interrupts here http://www.picbasic.co.uk/forum/showthread.php?p=23259 but I'm not sure how to add the include files. The website seems to be defunct now. Can someone please explain to me how to use the include files?
    Sep 2009
    Default Re: How to use include files?
    Files and some examples can be downloaded from here: http://www.picbasic.co.uk/forum/cont...aylors-s-works
    Thanks. But is there some sort of tutorial on how to actually install the include files?
    Sep 2009
    Just copy them in same folder as your .pbp file, that is all.
    Oct 2009
    and then add the include statement in your main code, placing whatever file you want to include in quotes, for example
    include "DT_INTS-18.bas"
    Thanks! I was confused as to how you "physically" got the include file in there. I didn't realize it was as simple as just putting the file in the same folder as your .pbp file.
    Oct 2009
    If you tend to use the same family of PICs, and the same hardware configurations (eg port B for an LCD display, or port A for input switches etc) then you can simply make one file with all the hardware definitions in, and then include that using one line in your main code.
    For example, I tend to use an 18F2620 or 18F4620 in most of my projects, and use the same LCD and pins for input switches so I have
    '  18F4620 config settings - for use with MPSAM
      __CONFIG    _CONFIG1H, _OSC_HS_1H
      __CONFIG    _CONFIG2L, _PWRT_ON_2L
      __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H
      __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    ' LCD (20 x 4) set up
    DEFINE LCD_DREG  PORTB                  ' LCD Data port
    DEFINE LCD_DBIT  0                      ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB                  ' LCD Enable port
    DEFINE LCD_EBIT  5                      '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB                  ' LCD Register Select port
    DEFINE LCD_RSBIT 4                      '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4                      ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4                      ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000               ' Command delay time in us
    DEFINE LCD_DATAUS 50                    ' Data delay time in us
    ' Defines Statements
    DEFINE  OSC 20                          ' 18F4520, 20mhz crystal
    ADCON1 = $0F
    clear
    'Analog and Comparator settings
    ADCON0 = %00000000                      'AD converter module disabled
    ADCON1 = %00001111                      'All Digital
    ADCON2 = %00000000
    CMCON = 7                               'Disable Comparators
    'Port and Register settings  (interrupts)
    TRISA  = %00010111
    TRISB  = %00000011
    TRISD  = %00000011
    T0CON  = %11000111
     ;----[UART Settings]------------------------------------------------------------
    DEFINE HSER_SPBRG 8   ' 9600 Baud @ SPBRGH = 2
    RCSTA = $90   ' Enable serial port & continuous receive
    TXSTA = $24   ' Enable transmit, BRGH = 1
    SPBRG = 8     ' 9600 Baud @ -0.03%
    SPBRGH = 2
    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
    RCIF                VAR PIR1.5                    ' USART receive flag
    Char                VAR BYTE                      ' USART byte received
    GIE                 VAR INTCON.7
    nTest               var byte
    ' Pins used for connections to outside world
    DecButton          var PORTA.0	        'Press to Decrement Button
    SetButton          var PORTA.1          'Press to Set/memorise Button
    IncButton          var PORTA.2	        'Press to Increment Button
    OnButton           var PORTA.0	        'Press to Decrement Button
    OffButton          var PORTA.2	        'Press to Increment Button
    H_butt             VAR PORTA.2          'hour increase
    M_butt             VAR PORTA.0          'minutes increase
    S_butt             VAR PORTA.1          'set / memorise
    SCLpin             var PORTC.3          'RTC pin - clk
    SDApin             var PORTC.4          'RTC pin - data
    led                var PORTD.4
    An then save that as "hardware18F4620" and then in the main program use the
    INCLUDE "hardware18F4620.pbp"
    Saves having to write out or copy and paste lots of code
    Aug 2003
    You can copy and paste it straight into your main file if you want to see it, or change it.
    There are times when the include file is annoying, such as any variable you want to add in the include file has to be
    declared before your main code (i.e. in the include file).
    Can one put an Include within an Include file?
    Have you tried?
    Well no, but really I'm wondering if there is a limitation. Multiple includes with includes within them. Since it all "happens" before compile time, I suppose it doesn't matter?
    As far as I know - no, it doesn't matter.
    Whatever is in the included file gets put, byte for byte, where the INCLUDE "thisorthatfile.pbp" line is placed so you can have a source file wich includes two other files, which each includes two other files and so on. It's not a good idea to include the SAME file more than once though, if that's a "risk" you need to use conditionals to make sure it's only "compiled in" once even though it's included at several places.
    Disclaimer: I haven't done anything like the above.
    Oct 2009
    The only issue I could see with having lots of include files for standard things, say routines for reading and RTC, writing to an EEPROM, updating an LCD etc is that you wouldn't have much code structure in the main program !
    Agreed Scampy, it could become more difficult to debug if there was some "hidden" conflict since it wouldn't be as readable.
    Aug 2016
    See below for Include file. This may help you.
    http://www.perlmonks.org/?node_id=393426
    Oct 2009
    In what way does perl scrip help with PicBASIC pro ?
  1. Post your INCLUDE files here
    By mackrackit in forum Code Examples
    Last Post: - 17th September 2011, 00:50
  2. Where are all the INCLUDE files??
    By Heckler in forum General
    Last Post: - 13th September 2011, 09:27
  3. Include Files for some Routines
    By rsocor01 in forum PBP Wish List
    Last Post: - 23rd April 2010, 20:13
  4. Using ASM files as include
    By Josuetas in forum mel PIC BASIC Pro
    Last Post: - 15th August 2007, 21:40
  5. Modified include files
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 19:39
