Need Help with PIC as SPI Slave
Results 1 to 4 of 4
    PICtron's Avatar
    PICtron Guest
    Question Mssp?
    Is there really no one who can help?
    I think the MSSP module is the one to use.
    But I'm really struggling with it.
    What registers are to be set and how do I set them?
    And how do I sync to the incomming datastream?
    Here some more details:
    Incomming data is in bursts of two packets (four bytes each packet).
    there is a delay of about 200µS between two packets of a burst
    and there is a delay of about 200 ms between two bursts.
    The clock idles HIGH
    I'm planning to use a 16F876A @ 20MHz
    Any code snippet or advise will be appreciated.
    PICtron's Avatar
    PICtron Guest
    Thanks for "many" replies
    I have found a solution to the problem on my very own!
    Where did you find the solution? I might be running into the same type of scenario as yourself. I however have choice of interfaces to use.
  1. Reading a slave USB with a pic
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 13:00
  2. Using SPI with External Interrupts
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 05:08
  3. 16-bit SPI problem
    Last Post: - 19th June 2008, 16:42
  4. SPI configuration PIC versus Atmel
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 10th July 2007, 20:17
  5. How to configure SPI in PICBASIC PRO?
