Error Messages
Results 1 to 5 of 5
Thread: Error Messages
    Jul 2006
    Lazio, Italy
    Default Error Messages
    I'm now using Picbasic Pro 3.0.6.1. When I INCLUDE "LCDbar_INC.bas", I have this error messages:
    Macro DIV32?WW not found in marco file
    Macro DIV32?CW not found in macro file
    can help me ? Thanks
    Default Re: Error Messages
    This is a longshot but I don't Think DIV32 is supported when compiling with LONGs enabled so if that's what you're doing try disabling LONGs and see if it will compile. If that's what's happening AND you're actually using LONGs in your program well, then you're screwed and will need to change LCDbar_INC.bas
    Jul 2006
    Lazio, Italy
    Thanks Henrik, you were right, if I disable LONGs is all ok. The problem is that I need both functions. Do you think there is no solution?
    OK, in that case I'm sorry for being right :-)
    No, short of digging into the LCD_Bar include file and replacing the code that is using the DIV32 macros with code that doesn't there is no solution.
    When you're using LONGs there's no need for the DIV32 command so it's not included in the LONG-enabled version of library files. It MIGHT be possible to "hack" them back in but I don't know how to do that.
    Without ever having looked at the LCD_Bar file(s) I think rewriting those is your best bet.
    Jul 2006
    Lazio, Italy
    Henrik thanks for your help and for your time. Regards
  1. help about error messages
    By fourtech in forum mel PIC BASIC Pro
    Last Post: - 20th February 2012, 10:25
  2. Warning & Error Messages
    By cc1984 in forum Forum Requests
    Last Post: - 23rd May 2011, 16:09
  3. Error messages
    By mombasa in forum mel PIC BASIC Pro
    Last Post: - 1st April 2010, 08:30
  4. Warning (and other Compilation Error) Messages
    Last Post: - 9th September 2009, 01:29
  5. error messages
    By jcleaver in forum mel PIC BASIC Pro
    Last Post: - 27th February 2007, 02:40
