Decline of PicBasic ?
Results 1 to 40 of 53
    Aug 2011
    Default Re: Decline of PicBasic ?
    There are literally millions of people developing arduino code and libraries. Compare that to the resources of melabs and I think it's pretty obvious who wins. Even if everyone who posts on this forum codes like mad it'll never reach the same level of market acceptance.
    Add to that the fundamental difference between the languages and environments (C/C++ vs basically an asm macro generator) and you'll be waiting a loooong time for features like the arduino has. Plus, the arduino tools are free.
    Apples and oranges if you ask me (not that you did).
    Oct 2009
    Oh I agree that being open source nothing can compare to it in terms of support and development. But then you have MikroElektronika - not only have they continued to develop the hardware (easyPIC / AVR range of development boards plus all the addons )- they are / have been developing their compilers, be that Basic or C++ . But then you are right, it's comparing apples and oranges given that MikroElektronika's turnover for 2016 was around £4,000,000, I suspect considerably more than crownhills for the same period based on the limited information available on the web.
    OK
    I'm aware of a "DT_INTS" type book in the works based on the marvelous contributions made by the late great Daryl Taylor. It doesn't compete with the myriad of code, libraries, and examples available for other platforms, but please don't discount the courageous efforts being taken by a select few in the PBP camp. Having looked into various offerings, I chose PIC and PBP for my reasons. I try to contribute where I can, and I sincerely hope the PBP/PIC niche will continue to grow & evolve. Instead of complaining about the lack of support, I try to give it in hopes that others will respond in kind when I need help. The simple answer is if you find yourself more comfortable with Audrino (or any other platform), work with it.
    I would not be too sure about that. I find the source level debug support is years behind and programmer support not much better for recent chips. I regularly have to use the pickit3 or icd3 on the easypic7 board now for the newer chips. the support for pps is pretty rudimentary also.
    imho mplabx/xc8/mcc leaves mikroc for dead now
    Oct 2009
    I just wanted to share an experience with you guys that is somewhat related to this project.
    I've had a 2.8" SPI serial TFT screen sitting in my electronics draw for sometime, and as there is nothing (or at least my searches turned up nothing) to support these devices in PBP I opted to get an Arduino Mega and experiment with that, given that there are lots of library files readily available. Now I've never attempted programming in C++ (or the variant the Arduino platform uses) so it was a steep learning curve (learning Klingon may have been simpler). But after a few days had managed to take one of the example files and hack it about to mimic the layout on the GLCD display in my existing vivarium controller project, only better as the display is colour. So what was going to be just an experiment to prove the TFT worked was now developing into a revision of my old PIC based project.
    Over the following couple of weeks I had downloaded examples for DS18B20's, DS1307 RTC, etc and with the help of a friend via e-mails adapted them to suit the projects needs. But the road was never smooth and easy. The strange syntax with brackets, semi-colons, and lack of structure like BASIC made things tricky. Simple things like reading the state of a switch and then jumping out of the main loop to a menu seems to be too low level that its complicated to detect the moment the switch is pressed. It ignores what logic would seem to be easy. For example using the included example that lights an LED when the button is pressed, substitute the making of pin high when the button is pressed to print something on the screen and it doesn't work. The biggest headache has been serial communications.... My PIC / PBP project can be updated via serial and a PC application written in Liberty Basic - it works just fine - replicating that in C++ has caused us so much frustration, whether serial ports on the processor are flakey, or there is a timing issues (no DT INT here ) we have no idea. I did manage to get reliable communications working, but that was the only thing happening, sending numbers back and forth and updating an array, add in the option of reading a single DS18B20 and displaying text on the TFT and the serial coms become unstable with data missing after transmission. I've used a com sniffer to confirm data movement, and the problem is code related.
    So for me it's a shame that PBP hasn't kept pace with things like TFT screens, Ethernet etc. After this experience with C++ I realise how much I love using PBP. Maybe given the input and development of routines by Darrel PBP would have been developed further to cover these items of hardware, but sadly we lost such a wonderful person with so much expertise. I just wish I had the skill and experience to be able to develop PBP include files to use TFTs, GLCDs etc but I'm no where near that talented.
    Having messed about with C++ I much prefer PBP and will, where possible, use this as my preferred language.
    did you upgrade to pbp3 ?
    did you upgrade to pbp3.1 ?
    is it any wonder progress has ceased ?
    if you upgraded to pbp3 the tft include I provided to the forum is a working system that everyone who has tried it has got functional
    all three of them that I know of.
    imho pbp is dead with a small amount of deckchair shuffling [on titanic] going on .
    I now have ported nearly all my code to xc8 , the mcc is a splendid thing for the chips it supports. my last stumbling block is usb-cdc, mcc seems to have missed usb support for the ubiquitous 18f4550
    Oct 2009
    Hi Richard,
    No I didn't upgrade at the time due to the cost and personal circumstances. Maybe it's something that I should look at, but then you have already stated that you are porting your contributions to another platform and will (by the sounds of things) no longer supporting PBP, so maybe it's not a good time for me to upgrade to PB3 given how quiet it is around here and I should consider other options.
    OK
    Frankly, after spending 2 years struggling with USB I bit the bullet & purchased HIDmaker. Using HIDmaker, I'm better understanding what I read about and fought with for 2 years. The punch line is I'm functional with USB now.
    Scampy and others, a very wise man once told me, "If it is to be, it is up to me." It's nice when I can post an issue on the forum and find someone that has tackled it already. However, when I can't, I just dive in and figure it out myself. All those wonderful Audrino Include files were developed by individuals with the attitude, "If it is to be, it is up to ME!"
  1. conversion from picbasic to picbasic pro
    By winjohan in forum mel PIC BASIC Pro
    Last Post: - 1st November 2011, 19:00
  2. does PicBasic do that?
    By HYETİK in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:53
  3. Proton PICBASIC vs MeLabs PICBASIC
    By Fredrick in forum General
    Last Post: - 11th January 2008, 22:51
  4. PICBasic Pro vs Proton PICBasic
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2006, 17:11
  5. PicBasic Pro & PicBasic syntax different
    By Billyc in forum General
    Last Post: - 16th April 2004, 22:19
Members who have read this thread : 4
