RMS vs Average voltage
Results 1 to 10 of 10
    Default Re: RMS vs Average voltage
    it has nothing to do with phase shift or inductive and capacitive loads its simple mathematics
    power is whats being measured here
    power = V squared / R
    the effective power is the sum of the instantaneous powers measured in your wave form, try it for a triangular wave
    R=1 ohm Vp=50 , Vave=25v Vrms=28.8
    Dec 2010
    For starters, the average of a sine wave for a full cycle is 0.
    yes Charlie the average voltage = 0 and the average current =0 yet the load resistor gets hot . perhaps you have just discovered dark energy
    Dec 2010
    Well, Richard, you did bring up the math. And the mathematical reason we don't use average is that it's no where near correct, in fact the average IS 0. This is a sine function, so calculating the absolute value average is a bit more complicated. You need to integrate the area under the curve as was outlined above. The way you do that is to square all the instantaneous values, take the average, then take the square root of that. For a sine function, that is the peak to peak value * square root of 2 (0.707)
  1. Moving Average and DIV32
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 29th September 2012, 18:54
  2. Best way to convert peak voltage to RMS?
    By HankMcSpank in forum General
    Last Post: - 1st June 2012, 19:32
  3. DT Average
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 6th October 2011, 23:47
  4. Average Values and digital filter ...
    By jorge in forum mel PIC BASIC Pro
    Last Post: - 24th April 2010, 12:29
  5. Math help - rolling average Wind Direction
    By wjsmarine in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2009, 00:08
