Protection Circuit
Results 1 to 10 of 10
    Oct 2009
    Default Re: Protection Circuit
    Thanks once again for the input guys. The 5v is purely to run the PIC, a DS1307, 2 x 16 LCD and a PCA9865, so not really a huge load, and whilst the 7805 is not efficient, for the purpose it does juts fine.
    I'll check out the FETs that Henrik suggest, and look for some fuses for the lights. Thinking about it, as the 12v flows through the lights it doesn't matter which way round they are connected as the lights have no polarity being small incandescent lamps, so reverse polarity on the connections to the lights isn't required.
    The lamps might not care but the 16 MOSFETs switching the current TO the lamps do "care" in the sense that if you get the polarity wrong their body diode will conduct and all the lamps will turn on. That might serve as an indication to the user that he just did something stupid...
    If that LCD has a backlight it might pull some current.
    PCA9865, what's that? Tried to Google for it but all I seem to get is 9685 which is a 16 channel LED dimmer IC, is that what you're using and if so are you driving the MOSFET gates with its output?
    The P-channel MOSFETs I suggested are just two I picked, like I said there are hundreds, if not thousands, to choose from. As for the fuses you may want to look at using a PTC.
    Oct 2009
    Thanks Henrik, yes it is a 9685 - dyslexic fingers !!
  1. Ibutton Protection Circuit (OneWire)
    By andybarrett1 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2014, 17:25
  2. RS232 and RS485 circuit protection
    By Luckyborg in forum Schematics
    Last Post: - 27th February 2013, 11:38
  3. Short circuit portection circuit ?
    By iugmoh in forum Schematics
    Last Post: - 21st December 2008, 21:33
  4. Replies: 3
    Last Post: - 29th October 2006, 09:16
  5. Overdischarge protection for a li-ion powered circuit
    By peu in forum mel PIC BASIC Pro
    Last Post: - 7th October 2006, 12:34
