Pb3 pic12lf1571 asm error
Results 1 to 2 of 2
    Jun 2005
    Default Pb3 pic12lf1571 asm error
    I am attempting to program a PIC12F1571 in PBP3 and not sure why I am getting the following ASM ERRORs.
    I am not using the serial port. I updated to the latest PB3 3.0.9.4 &it updated MPLAB.
    Error[113] C:\PBP3\EXAMPLES\1571.ASM 45 : Symbol not previously defined (_LPBOR_OFF)
    Error[113] C:\PBP3\PBPPI14E.LIB 2453 : Symbol not previously defined (TXIF)
    Error[113] C:\PBP3\PBPPI14E.LIB 2480 : Symbol not previously defined (TXREG)
    Error[113] C:\PBP3\PBPPI14E.LIB 2481 : Symbol not previously defined (TXREG)
    Error[113] C:\PBP3\PBPPI14E.LIB 584 : Symbol not previously defined (SPBRG)
    Error[113] C:\PBP3\PBPPI14E.LIB 919 : Symbol not previously defined (SPBRG)
    Error[113] C:\PBP3\PBPPI14E.LIB 584 : Symbol not previously defined (TXSTA)
    Error[113] C:\PBP3\PBPPI14E.LIB 919 : Symbol not previously defined (TXSTA)
    Error[113] C:\PBP3\PBPPI14E.LIB 584 : Symbol not previously defined (RCSTA)
    Error[113] C:\PBP3\PBPPI14E.LIB 919 : Symbol not previously defined (RCSTA)
    __config _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _BOREN_ON & _CLKOUTEN_OFF
    __config _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_ON & _BORV_LO & _LPBOREN_OFF & _LVP_OFF
    DEFINE OSC 20 ' system clock at 20MHz
    DEFINE ADC_BITS 10 ' A/D number of bits
    DEFINE ADC_CLOCK 1 ' Uses A/D internal RC clock
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time in us
    DEFINE HPWM_OSC 16000000 ' PWM clock at 16MHz
    ADCON1.7 = 1
    TRISA = %00000100
    ANSELA = %00000100
    A VAR word 'Stores 10 Bit Analog Reading
    B var byte
    mainloop:
    b = 0
    porta.4 = 1
    pause 2500
    porta.4 = 0
    pause 2500
    goto mainloop ' Do it all over again
    Default Re: Pb3 pic12lf1571 asm error
    Seems to compile fine here using 3.0.8.4
    Make sure you use MPASMX, if I don't I get all sorts of error. If you're using MicroCodeStudio then View -> Compile & Program Options -> Use MPASMX Assembler.
  1. Getting around asm - argument out of range - error
    By longpole001 in forum mel PIC BASIC Pro
    Last Post: - 14th May 2015, 10:33
  2. Missing Operator ASM error
    Last Post: - 18th June 2012, 07:26
  3. PB3, which error is it ?
    By Marcick in forum mel PIC BASIC Pro
    Last Post: - 1st May 2012, 16:12
  4. micro code studio plus asm error
    By cesurcelik in forum mel PIC BASIC Pro
    Last Post: - 5th December 2005, 13:14
  5. Undefined Symbol error when using ASM interrupt
    By toalan in forum mel PIC BASIC Pro
    Last Post: - 11th January 2005, 21:41
