updated and cannot compile
Results 1 to 4 of 4
    Default Re: updated and cannot compile
    In the past that message usually was the result of includig CONFIG in your program while they are still "Active" in the device specific include file. However, with PBP3 the way this is handled changed for the better so the question is if the program you're trying to compile now was written before you upgraded to PBP3 AND that it has the old way of handling the CONFIG bits in it. (?)
    Aug 2009
    Paso Robles California
    You were right on, took a look at my config and it was old style I did try to use manual config and it made no difference once I used #config it worked
    thank you very much
  1. E8 will not compile
    By l_gaminde in forum mel PIC BASIC Pro
    Last Post: - 1st May 2013, 21:36
  2. Just updated from 2.60C to PBP3!!!!
    By MarioC in forum General
    Last Post: - 11th April 2012, 06:42
  3. PicBasic Pro Compiler manual updated with bookmarks
    By mtripoli in forum Documentation
    Last Post: - 8th March 2011, 01:49
  4. will not compile
    Last Post: - 20th September 2010, 20:37
  5. Can't compile
    By Lilmanmgf in forum mel PIC BASIC Pro
    Last Post: - 22nd October 2006, 20:17
