updated and cannot compile
Results 1 to 4 of 4
    Aug 2009
    Paso Robles California
    Default updated and cannot compile
    I received a notice that i needed to upgrade so i went to the link and updated and now none of my programs will compile I get this message
    ERROR: Unable to execute mpasmwin.Skipping link step. Not all sources built successfully.
    BUILD FAILED: Sun Jun 05 14:12:14 2016
    I know it in the path but I don't know what its looking for
    Aug 2009
    Default Re: updated and cannot compile
    ok I think i have the first problem fixed can compile my old programs but now I take an old program rename it and try to make a new project and get a warning red flag
    Error[118] C:\0 FILES\PBP-MPLAB\7794-DEALER-5 HO-MCOR.ASM 163 : Overwriting previous address contents (2007)
    BUILD FAILED: Sun Jun 05 16:19:06 2016
    In the past that message usually was the result of includig CONFIG in your program while they are still "Active" in the device specific include file. However, with PBP3 the way this is handled changed for the better so the question is if the program you're trying to compile now was written before you upgraded to PBP3 AND that it has the old way of handling the CONFIG bits in it. (?)
    Aug 2009
    You were right on, took a look at my config and it was old style I did try to use manual config and it made no difference once I used #config it worked
    thank you very much
  1. E8 will not compile
    By l_gaminde in forum mel PIC BASIC Pro
    Last Post: - 1st May 2013, 21:36
  2. Just updated from 2.60C to PBP3!!!!
    By MarioC in forum General
    Last Post: - 11th April 2012, 06:42
  3. PicBasic Pro Compiler manual updated with bookmarks
    By mtripoli in forum Documentation
    Last Post: - 8th March 2011, 01:49
  4. will not compile
    Last Post: - 20th September 2010, 20:37
  5. Can't compile
    By Lilmanmgf in forum mel PIC BASIC Pro
    Last Post: - 22nd October 2006, 20:17
