OT - Bluetooth serial comms issues
Results 1 to 5 of 5
    Oct 2009
    Default Re: OT - Bluetooth serial comms issues
    Seems the logic level shifter is the cause. Using simple voltage dividers on both RX and TX lines it worked fne
    Are you VCCA and VCCB are connected to the correct voltages? Also are you sure you have the correct logic level inputs/outputs connected to the correct level shift pins?
    EN82fn
    Oct 2009
    Hi Dave,
    Yes, 3.3v and 5v sides are correct voltages, and I tried all the pins A1-B1, A2-B2 etc
  1. OT - (slightly) - Bluetooth issues
    By Scampy in forum Off Topic
    Last Post: - 26th June 2015, 20:43
  2. 12F683 Serial Comms
    By ross246 in forum Serial
    Last Post: - 17th November 2010, 16:38
  3. PC Serial comms
    By Bill Legge in forum Serial
    Last Post: - 13th December 2009, 23:37
  4. PIC12F675 comms issues
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 25th March 2007, 04:24
  5. Serial comms / Bootloader
    Last Post: - 30th October 2005, 18:48
