Pic18 and RN42 bluetooth communication problem using UART
Results 1 to 10 of 10
    May 2016
    Default Pic18 and RN42 bluetooth communication problem using UART
    Hello everyone,
    I have a RN42 bluetooth module in HID profile that I am trying to get it working with PIC18F24J50.
    I have a code in arduino that is working and basically moves the cursor.I want to do the same in Basic but it doesn't work.
    Code in Arduino :
    int led = 13;
    void mouseAction(void);
    void setup() {
      pinMode(led, OUTPUT);
      digitalWrite(led, HIGH);
      Serial.begin(115200);
      delay(500);
      digitalWrite(led, LOW);
    void loop() {
        mouseAction(0,0,10,0);
    void mouseAction(int button,int x, int y,int wheel)
      Serial.write(0xFD);
      Serial.write(0x05);
      Serial.write(0x02);
      Serial.write(button)
      Serial.write(x);
      Serial.write(y);
      Serial.write(wheel);
      delay(20);
    And this is the Basic code:
    DEFINE LOADER_USED 1
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_BAUD 115200
    DEFINE HSER_SPBRG 1 ' 115200 Bauds
    DEFINE HSER_CLOERR 1
    SPBRG = 1
    RCSTA = 010000
    TXSTA = 100100
    TRISC.0 = 0
    TRISC.6 = 0
    TRISC.7 = 1
    LED VAR PORTC.0
    mainloop:
        high LED
       'TXREG = $FD
       'TXREG = $05
       'TXREG = $02
       'TXREG = 0
       'TXREG = 0
       'TXREG = 10
       'TXREG = 0
        Hserout [$FD]
        Hserout [$05]
        Hserout [$02]
        Hserout [0]
        Hserout [0]
        Hserout [10]
        Hserout [0]
       Pause 1000
       low LED
       Pause 1000
       Goto mainloop
    It doesn't work using 4Mhz internal oscillator and I wonder if that is problem and a 24 external oscillator will fix it or the is problem with my code?
    I am a bit new to UART using Pic18 and I would appreciate anyway help.Thanks!
    Default Re: Pic18 and RN42 bluetooth communication problem using UART
    @ 4mHz The baudrate error is 8.5 % .Quite likely to cause trouble , the internal osc is quite capable of 8 12 16 24 or 48 MHz operation any one of which would be better than 4 .
    SPBRG = 1   why ?  DEFINE HSER_SPBRG 1
    RCSTA = 010000 ?   even with %010000 its still wrong and conflicts with DEFINE HSER_RCSTA 90h
    TXSTA = 100100  ?  even with %100100 its  redundant
    May 2016
    I changed the oscillator value but it still doesn't work.
    I think it could be because of missing line in arduino code to enter command mode!
    Serial.print("$$$")
    Any suggestion on doing the same thing in Basic? How do I do it? using Hserout? Not sure about sending ASCII string.
    Would appreciate any help.
    Serial.write(x);
    Serial.write(y);
    wheel ,x,y and button are all ints ie 16 bit signed values ie 8 bytes sent
    Hserout [0]
    Hserout [0]
    Hserout [10]
    Hserout [0]
    are all bytes ie 8 bit unsigned values ie 4 bytes sent
    post your code including the fuse config
    May 2016
    How should I enter ints 16 bit signed values? like following?
        Hserout [0]
        Hserout [0]
        Hserout [0]
        Hserout [0]
        Hserout [10]
        Hserout [0]
        Hserout [0]
        Hserout [0]
    New Code with config:
    DEFINE HSER_SPBRG 7 ' 115200 Bauds
    DEFINE OSC 16
    TRISC.0 = 0
    TRISC.6 = 0
    TRISC.7 = 1
    LED VAR PORTC.0
        Hserout ["$$$"]   'command mode Serial.print("$$$");
    mainloop:
        high LED
        Hserout [$FD]
        Hserout [$05]
        Hserout [$02]
        Hserout [0]
        Hserout [0]
        Hserout [10]
        Hserout [0]
       Pause 1000
       low LED
       Pause 1000
       Goto mainloop
    Thanks again for the help! I am stuck!
    to send 10
    in little_endian format
    Hserout [10,0]
    or big_endian format
    Hserout [0,10]
    not sure how arduinos go about it they could be big or little endian
    if your values can be negative then you need to pay close attention to your calcs pbp uses unsigned math
    there is no config there
    pbp default config for pic18f24j50 is
      CONFIG  WDTEN = ON
      CONFIG  PLLDIV = 5
      CONFIG  STVREN = ON
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CPUDIV = OSC1
      CONFIG  CP0 = OFF
      CONFIG  OSC = HSPLL
      CONFIG  T1DIG = ON
      CONFIG  LPT1OSC = OFF
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  WDTPS = 512
      CONFIG  DSWDTOSC = INTOSCREF
      CONFIG  RTCOSC = T1OSCREF
      CONFIG  DSBOREN = ON
      CONFIG  DSWDTEN = ON
      CONFIG  DSWDTPS = G2
      CONFIG  IOL1WAY = ON
      CONFIG  MSSP7B_EN = MSK7
      CONFIG  WPFP = PAGE_0
      CONFIG  WPEND = PAGE_WPFP
      CONFIG  WPCFG = OFF
      CONFIG  WPDIS = OFF
    which expects an external xtal
    DEFINE OSC 16
    is just a compiler directive used for compile time timing calculations , it does nothing else
    to use the internal osc the config words need to be set appropriately
    such as
    CONFIG OSC = INTOSC
    or
    CONFIG OSC = INTOSCPLL
    and
    CONFIG PLLDIV needs to match
    along with
    CONFIG CPUDIV which need to match
    read the osc section of the data sheet
    May 2016
    Thanks alot! I will try that.
    Do I need to set OSCCON and OSCTUNE registers as well if I am using internal oscillator? I am a bit confused about Frequency Tuning bit of OSCTUNE register.How you get to 16MHz from 96 MHz PLL?
    for 16mhz
      CONFIG  WDTEN = ON
      CONFIG  PLLDIV = 2
      CONFIG  STVREN = ON
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CPUDIV = OSC3_PLL3
      CONFIG  CP0 = OFF
      CONFIG  T1DIG = ON
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  WDTPS = 512
      CONFIG  DSBOREN = ON
      CONFIG  DSWDTEN = ON
      CONFIG  DSWDTPS = G2
      CONFIG  IOL1WAY = ON
      CONFIG  WPCFG = OFF
      CONFIG  WPDIS = OFF
    OSCTUNE.6=1  ; pll enable
    8mhz   -----/2 --= 4---pll--= 96 -/2 = 48  ------/3--  =   16
    inc osc   pll pre               pll            cpu div
    Last edited by richard; - 31st May 2016 at 10:16. Reason: white space is nearly impossible
    May 2016
    I got it running using external oscillator but bluetooth doesn't pickup the commands..
    Any idea? even
    Hserout [dec 10]
    doesn't work.
    May 2016
    Actually It's working using what you suggested.
    Hserout [10,0]
    Thanks alot!
  1. usart-bluetooth problem
    By murat44 in forum mel PIC BASIC Pro
    Last Post: - 5th February 2015, 18:00
  2. Communication using a Bluetooth module
    By Balachandar in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2013, 08:56
  3. uart problem
    By OYMYAKON in forum mel PIC BASIC Pro
    Last Post: - 25th March 2011, 11:52
  4. Bluetooth SKKCA communication failure
    By Rameesh in forum Bluetooth
    Last Post: - 23rd June 2008, 13:32
  5. Pic18 Syntax problem
    By Philip Biebach in forum mel PIC BASIC Pro
    Last Post: - 19th January 2006, 06:27
