File won't compile in PBP 2.6
Results 1 to 12 of 12
Threaded View
  1. #2
    Default Re: File won't compile in PBP 2.6
    On the 16F1827 there is no PortC and therefor no TrisC either which would explain the first two errors. The others seems to indicate that the program is too big, which I doubt if it's what you say it is so it might just be a problem due to the first error. If they don't go away you're going to have to post the code so we can see it.
    EDIT: Hmm, it says Program word too large.... So it's probably NOT the "length" of the program it's complaining about after all. But again, if it doesn't go away we (or I at least) need to see the code.
  1. Darryl's MIBAM code: won't compile for me!
    By Experimenter in forum mel PIC BASIC Pro
    Last Post: - 10th April 2014, 20:54
  2. Replies: 6
    Last Post: - 21st April 2013, 16:47
  3. Finally trying to do some serial- Won't compile :(
    By cncmachineguy in forum mel PIC BASIC Pro
    Last Post: - 26th January 2011, 17:25
  4. 16F877A Microcode Studio won't compile
    By curt66111 in forum mel PIC BASIC Pro
    Last Post: - 25th November 2009, 20:35
  5. Replies: 2
    Last Post: - 10th July 2006, 02:05
