OLED Display Noise problem
Results 1 to 25 of 25
    Nov 2007
    West Covina, CA
    Default Re: OLED Display Noise problem
    You can only "see" so fast before it becomes a blur.
    Try adding a PAUSE 33 in your main loop as it is, making it 30fps, just to test if the ghost dots go away.
    Louie
    Dec 2012
    Türkiye
    Quote Originally Posted by LinkMTech View Post
    Tried but still no luck
    - Ipsa scientia potestas est -
    Bombay, India
    Have you got your decoupling capacitors on board?
    Dec 2012
    Türkiye
    Yes I have tried a several values of capacitors even those large capacitors around 470uf and smaller ones and also together but it doesn't help ..
    Sep 2009
    Try something like this
    lcdout $FE,$28
    lcdout $FE,$17
    lcdout $FE,$06
    lcdout $FE,$08
    lcdout $FE,$01
    lcdout $FE,$02
    lcdout $FE,$0C
    lcdout $FE,$80,"BU BiR DENEMEDiR"
    LCDOUT $FE,$C0,"  iKiNCi SATIR  "
    GOTO Main
    And remove everything from board except power supply, PIC and LCD. Add 10uF, 100nF, 10nF capacitors to LCD power pins, preferably use SMD.
    If problem still persist then problem is in LCD. Or it can be "dirty" power supply. You didn't post schematic, so...
    You said that you need to display data as fast as possible. If that is really what you need, then use 7 segment led display. And you can get 3-4K FPS, but then you need super human to read that.
    If only regular humans will read display then more then 4 or 5 updates is more then enough.
    Look at multimeter Display Digital: 6,000 counts, updates 4 per second
    http://en-us.fluke.com/products/digi...html#techspecs
    Dec 2012
    Türkiye
    lcdout $FE,$28
    lcdout $FE,$17
    lcdout $FE,$06
    lcdout $FE,$08
    lcdout $FE,$01
    lcdout $FE,$02
    lcdout $FE,$0C
    GOTO Main
    It is not a regular eye read actually I am planning to make a vumeter to read that's why I need that fast readings ...
  1. Winstar OLED Display Problem with lcdout comands
    By bubbleless in forum mel PIC BASIC Pro
    Last Post: - 31st December 2019, 05:53
  2. Help With OLED Display / 128X64 SSD1306
    By Denner in forum General
    Last Post: - 25th May 2013, 15:40
  3. Problem with GOSUB/GOTO and Newhaven OLED question
    Last Post: - 12th April 2013, 10:24
  4. Pretty Sure a Noise Problem
    By Tobias in forum General
    Last Post: - 10th December 2009, 00:46
  5. OLED 128x128 color display
    By Ron Marcus in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 01:45
