That sound to me as bad PCB design and/or power supply. But sill could be bad LCD driver.
If long delays make artifact disappear, then capacitive coupling between LCD signals and power lines can cause that.
You can try test that. Add pull down resistor 1K to LCD Enable pin, and create easy way to disconnect LCD and resistor from PIC, as close as possible to LCD.
lcdout $FE,$28
lcdout $FE,$17
lcdout $FE,$06
lcdout $FE,$08
lcdout $FE,$01
lcdout $FE,$02
lcdout $FE,$0C
lcdout $FE,$80,"BU BiR DENEMEDiR"
LCDOUT $FE,$C0,"  iKiNCi SATIR  "
PAUSE 10000' Disconnect only LCD enable pin before pause timeout
GOTO Main
Display shouldn't update any more. If you see dots then 99% problem is with PCB layout, and decoupling.
If there is no dots on LCD then problem is with LCD.
Well ;
I did exactly as you asked me to do and as you say it's got to do with the lcd then ...
