High out of memeory errors with mcsx and win10 64b
Results 1 to 3 of 3
    Feb 2012
    PERTH AUSTRALIA
    Default High out of memeory errors with mcsx and win10 64b
    HI , GUYS
    about 3 months back i loaded win10 64b ver on the system that i run MCSX editor / compiler on
    ever since then i on average get about 4-5 "out of Memory " errors a day ,
    done the search for win 10 based issues and have tried them , but MCSX is the only one that crashes
    it used to happen win 7 64b occasionally but not as much as it now does under win 10
    has anyone found any fixes that may be forth a try
    i often save the program files every 10 mins - 15mins and so buffers should not be an issue , and the unit has 16gig of mem on the system and the logs show it never gets even close to being used
    its starting be come a real issue and i would like to solve it if any have answer
    cheers
    sheldon
    Feb 2012
    PERTH AUSTRALIA
    Default Re: High out of memeory errors with mcsx and win10 64b
    so am i alone is this problem or is it that no one has a solutiion , or both
    I guess the second...
  1. Replies: 9
    Last Post: - 27th January 2015, 13:57
  2. Replies: 10
    Last Post: - 14th April 2014, 20:47
  3. MCSX not fully loading, anyone else?
    Last Post: - 2nd February 2013, 05:28
  4. high voltage high frequency H-Bridge
    By George in forum Off Topic
    Last Post: - 27th April 2009, 11:50
  5. 10F206 Errors
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 24th November 2005, 20:48
