Hi Sabahan,
I would start by going to the "device_reference" folder for PBP (what version of PBP are you using?)
C:\PBP3\DEVICE_REFERENCE
then open up the .info file for your device
inside there you should find information for what to put in your configuration statements
partial example of a .info file ...
; File: PIC18F45K22.INFO
; Date: 07/24/11
; Generated by melabs File Manager
; PICBASIC PRO(tm) Compiler version: 3.0.0.x
; Copyright 2011 microEngineering Labs, Inc. All Rights Reserved
; The content herein is intended to facilitate embedded development using
; PICBASIC PRO Compiler. Reproduction or utilization for other purposes
; is prohibited without written permission from microEngineering Labs, Inc..
; microEngineering Labs, Inc.
; 2845 Ore Mill Road STE 4
; Colorado Springs, CO 80904
; 719-520-5323
; fax: 719-520-1867
; http://melabs.com
; [email protected]
; Modifications to this file in the \DEVICE_REFERENCE folder will be overwritten when
; you install future upgrades.
;MPASM CONFIG Directive Options
; This section is included for reference only. The following options may
; be used with the MPASM CONFIG directive to specify configuration settings
; in the source program using the #CONFIG/#ENDCONFIG block.
; Example:
; #CONFIG
; CONFIG OSC = HS
; CONFIG WDTE = ON
; #ENDCONFIG
; Oscillator Selection bits
; CONFIG FOSC = RC ;111X External RC oscillator, CLKOUT function on RA6
; CONFIG FOSC = ECLPIO6 ;EC oscillator (low power, <500 kHz)
; CONFIG FOSC = ECLP ;EC oscillator, CLKOUT function on OSC2 (low power, <500 kHz)
; CONFIG FOSC = ECMPIO6 ;EC oscillator (medium power, 500 kHz-16 MHz)
; CONFIG FOSC = ECMP ;EC oscillator, CLKOUT function on OSC2 (medium power, 500 kHz-16 MHz)
; CONFIG FOSC = INTIO7 ;Internal oscillator block, CLKOUT function on OSC2
; CONFIG FOSC = INTIO67 ;Internal oscillator block
; CONFIG FOSC = RCIO6 ;External RC oscillator
; CONFIG FOSC = RC ;External RC oscillator, CLKOUT function on OSC2
; CONFIG FOSC = ECHPIO6 ;EC oscillator (high power, >16 MHz)
; CONFIG FOSC = ECHP ;EC oscillator, CLKOUT function on OSC2 (high power, >16 MHz)
; CONFIG FOSC = HSMP ;HS oscillator (medium power 4-16 MHz)
; CONFIG FOSC = HSHP ;HS oscillator (high power > 16 MHz)
; CONFIG FOSC = XT ;XT oscillator
; CONFIG FOSC = LP ;LP oscillator
; 4X PLL Enable
; CONFIG PLLCFG = OFF ;Oscillator used directly
; CONFIG PLLCFG = ON ;Oscillator multiplied by 4
; Primary clock enable bit
; CONFIG PRICLKEN = OFF ;Primary clock can be disabled by software
; CONFIG PRICLKEN = ON ;Primary clock is always enabled
; Fail-Safe Clock Monitor Enable bit
; CONFIG FCMEN = OFF ;Fail-Safe Clock Monitor disabled
; CONFIG FCMEN = ON ;Fail-Safe Clock Monitor enabled
; Internal/External Oscillator Switchover bit
; CONFIG IESO = OFF ;Oscillator Switchover mode disabled
; CONFIG IESO = ON ;Oscillator Switchover mode enabled
; Power-up Timer Enable bit
; CONFIG PWRTEN = OFF ;Power up timer disabled
; CONFIG PWRTEN = ON ;Power up timer enabled
; Brown-out Reset Enable bits
; CONFIG BOREN = SBORDIS ;Brown-out Reset enabled in hardware only (SBOREN is disabled)
; CONFIG BOREN = NOSLP ;Brown-out Reset enabled in hardware only and disabled in Sleep mode (SBOREN is disabled)
; CONFIG BOREN = ON ;Brown-out Reset enabled and controlled by software (SBOREN is enabled)
; CONFIG BOREN = OFF ;Brown-out Reset disabled in hardware and software
; Brown Out Reset Voltage bits
; CONFIG BORV = 190 ;VBOR set to 1.90 V nominal
; CONFIG BORV = 220 ;VBOR set to 2.20 V nominal
; CONFIG BORV = 250 ;VBOR set to 2.50 V nominal
; CONFIG BORV = 285 ;VBOR set to 2.85 V nominal
; Watchdog Timer Enable bits
; CONFIG WDTEN = ON ;WDT is always enabled. SWDTEN bit has no effect
; CONFIG WDTEN = SWON ;WDT is controlled by SWDTEN bit of the WDTCON register
; CONFIG WDTEN = NOSLP ;WDT is disabled in sleep, otherwise enabled. SWDTEN bit has no effect
; CONFIG WDTEN = OFF ;Watch dog timer is always disabled. SWDTEN has no effect.
then at the top of your code do something like this...
           __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_OFF & _MCLRE_OFF & _CP_ON & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
           __CONFIG _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_25 & _LVP_OFF
    #endconfig
good luck
dwight
