siren sound with tmr0
Results 1 to 10 of 10
    Mar 2014
    Default siren sound with tmr0
    Hi Everyone!
    I wanna make siren sound with 16f628a and timer0.
    I find on the web and found the tmr0 solution. I did make program, but can't take good result.
    Do you have sample program for me with tmr0 interrupt.
    Thank you.
    Oct 2009
    Default Re: siren sound with tmr0
    Post up the code you have (use the "code /code " tags) and state what the actual problem is and I'm sure someone will offer assistance
    Mar 2014
    Quote Originally Posted by Scampy View Post
    Hi I am using tmro interrupt.
    My program is;
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF &_BODEN_ON & _LVP_OFF & _DATA_CP_OFFON INTERRUPT GoTo VAIL
    OPTION_REG=000001
    define OSC 4
    CMCON=7
    INTCON=100000
    trisa=0
    trisb=0
    porta=0
    portb=0
    SYMBOL SES=PORTA.1
    t var word
    a1 var byte
    a var byte
    x var byte
    a=0:a1=55:t=0:x=0
    tmr0=55
    wail:
    goto wail
    VAIL:
    disable
    TOGGLE SES
      t=t+1
            if t=20 and a=0 then
            t=0
            a1=a1+1
            if a1>242 then a=1
            if t=125 and a=1 then
            t=0
            a1=a1+1
            if a1>245 then a=2
            if t=125 and a=2 then
            t=0
            a1=a1-1
            if a1<242 then a=3
            if t=20 and a=3 then
            t=0
            a1=a1-1
            if a1=<55 then a=0
    tmr0=a1
    INTCON.2=0
    resume
    enable
    anyone can help me for this?
    Oct 2009
    a=0:a1=55:t=0:x=0
    tmr0=55
    wail:
    goto wail
    VAIL:
    disable
    well this may be one reason... it's looping but doing nothing in-between
    a=0:a1=55:t=0:x=0
    tmr0=55
    wail:
    goto wail
    VAIL:
    disable
    I think that is ok, it loops until tmr0 interrupts on overflow.
    I have never used ON INTERRUPT, but I see some mistakes probably from cut and paste. ON INTERRUPT should be on a separate line, not in the configurations
    OPTION_REG and INTCON need % in front of the binary numbers
    enable at the end of the code will never happen, since resume returns us to the main program.
    What else?
    OPTION_REG=000001
    define OSC 4
    CMCON=7
    INTCON=100000
    trisa=0
    trisb=0
    porta=0
    portb=0
    SYMBOL SES=PORTA.1
    t var word
    a1 var byte
    a var byte
    x var byte
    a=0:a1=55:t=0:x=0
    tmr0=55
    wail:
    goto wail
    VAIL:
    disable
    TOGGLE SES
      t=t+1
            t=0
            a1=a1+1
            if a1>242 then a=1
            t=0
            a1=a1+1
            if a1>245 then a=2
            t=0
            a1=a1-1
            if a1<242 then a=3
            t=0
            a1=a1-1
            if a1=<55 then a=0
    tmr0=a1
    INTCON.2=0
    resume
    enable
    Mar 2014
    Quote Originally Posted by mark_s View Post
    What else?
    OPTION_REG=000001
    define OSC 4
    CMCON=7
    INTCON=100000
    trisa=0
    trisb=0
    porta=0
    portb=0
    SYMBOL SES=PORTA.1
    t var word
    a1 var byte
    a var byte
    x var byte
    a=0:a1=55:t=0:x=0
    tmr0=55
    wail:
    goto wail
    VAIL:
    disable
    TOGGLE SES
      t=t+1
            t=0
            a1=a1+1
            if a1>242 then a=1
            t=0
            a1=a1+1
            if a1>245 then a=2
            t=0
            a1=a1-1
            if a1<242 then a=3
            t=0
            a1=a1-1
            if a1=<55 then a=0
    tmr0=a1
    INTCON.2=0
    resume
    enable
    Hi Marks
    You are right. İt is problem related to copy paste selection.
    I looked to my program on the editor mode, it is right.
    I am using this program on the isus simulation program.
    All commands is good, without one position.
    High frequency sound is very bad. I am trying to make good sound this frequency.
    I asked you , if you have sapmle code related this program pls share for me.
    Thank you for your interest.
  1. Police Siren like Barricade has?
    By DanPBP in forum Off Topic
    Last Post: - 4th June 2016, 20:28
  2. intervall timer siren
    By oeloeg in forum mel PIC BASIC Pro
    Last Post: - 7th August 2011, 16:46
  3. TMR0 as counter
    Last Post: - 31st March 2009, 19:34
  4. Tmr0
    By laughing-gravy in forum mel PIC BASIC
    Last Post: - 19th February 2007, 19:51
  5. Sound and sound control with minimal parts
    By bartman in forum General
    Last Post: - 18th January 2005, 14:08
