siren sound with tmr0
Results 1 to 10 of 10
    Oct 2009
    Default Re: siren sound with tmr0
    I found this on the net, no idea if it works, but the code is very well commented and may help you with your project. Note the hardware too
    https://www.scribd.com/doc/103363423...icrocontroller
    And another project, but in mikroC which may be easier to convert to PBP http://www.electroschematics.com/873...ecurity-alarm/
    Mar 2014
    Quote Originally Posted by Scampy View Post
    Hi Scampy;
    Thank you for your solutions.
    I saw this project on the web, these are related , simple siren sound.
    I wanna professional siren sound. I saw more softwear on the web, all softwear writing asm language.
    Then I decide to learn asm.
    İt is mine solutions.
    Thank you
    I think this the one you are trying to do?
    It would be fun to port this to pic basic. I found the original assembly program for a pic16f84. The guy in the video uses a pic16f676. You can find more info if you google "Pic micro Multi Siren"
    I don't have time to try it right now
    ;LABLE          OPCODE          OPERAND         COMMENTS
                    list            R=DEC           ;Set radix to decimal
                    list            P=16F84A         ;Set device to pic16F84
                    list            F=INHX8m        ;Set format intel 8 bit merged
    ;                list            F=picice        ;picice format
    ;SETTING UP LABLES
    port_a          equ             5h              ;equate port a
    port_b          equ             6h              ;equate port b
    same            equ             1               ;same register
    _pc             equ             02h             ;program counter
    _rtcc           equ             01h             ;rtcc
    indirect        equ             00h             ;indirect address contents
    _fsr            equ             04h             ;file select register
    _status         equ             03h             ;status register
    _carry          equ             0               ;carry flag
    _zero           equ             2               ;zero flag
    ;               equ             10h             ;
    ;               equ             11h             ;
    ;               equ             12h             ;
    _lenth          equ             13h             ;
    ;               equ             17h             ;
    temp1           equ             14h             ;
    temp2           equ             15h             ;
    temp3           equ             16h             ;
    temp4           equ             1Ah             ;
    temp5           equ             1Bh             ;
    dipval          equ             1Ch             ;
    ;               equ             1Dh             ;
    ;               equ             1Eh             ;
    ;               equ             1Fh             ;
    ;               equ             0Fh             ;
    ;               equ             0Dh             ;
    ;               equ             0Bh             ;
    ;               equ             09h             ;
    ;               equ             08h             ;
    ;               equ             0Ah             ;
    ;               equ             0Eh             ;
    _flags          equ             0Ch             ;flag register
    ;               equ             18h             ;
    ;               equ             19h             ;
    ;port b pin definitions
    ;                equ             3               ;
    ;                equ             2               ;
    ;                equ             1               ;
    sir              equ             0               ;siren drive out
    ;flags
    ;               0                               0=siren sweep off
    ;                                               1=siren sweep on
    ;               1                               0=
    ;                                               1=
    ;               2                               0=
    ;                                               1=
    ;               3                               0=
    ;                                               1=
    ;               4                               0=
    ;                                               1=
    ;               5                               0=
    ;                                               1=
    ;               6                               0=
    ;                                               1=
    ;               7                               0=
    ;                                               1=
    ;page 0
                    ORG             000h            ;originate code here
    ;Codes start here
    init            movlw           B'01111111'     ;7 output
                    tris            port_b          ;
                    clrf            port_b          ;resetting port b
                    movlw           B'11111111'     ;
                    tris            port_a          ;
                    clrf            port_a          ;resetting port a
                    movlw           B'00001111'     ;setup  wdt 128:1
                    option                          ;pul ups off int clock enabled
                    clrf            _flags          ;clear all flags
    diptest         movf            port_b,w        ;get dip value
                    movwf           dipval          ;
                    comf            dipval,same     ;
                    bcf             dipval,7        ;mask
                    bcf             dipval,6        ;
                    bcf             dipval,5        ;
                    bcf             dipval,4        ;
                    movlw           15              ;
                    subwf           dipval,w        ;
                    btfsc           _status,_carry  ;set is pos
                    goto            op              ;
                    movlw           14              ;
                    subwf           dipval,w        ;
                    goto            op14            ;
                    movlw           13              ;
                    subwf           dipval,w        ;
                    goto            op13            ;
                    movlw           12              ;
                    subwf           dipval,w        ;
                    goto            op12            ;
                    movlw           11              ;
                    subwf           dipval,w        ;
                    goto            op11            ;
                    movlw           10              ;
                    subwf           dipval,w        ;
                    goto            op10            ;
                    movlw           9               ;
                    subwf           dipval,w        ;
                    goto            op9             ;
                    movlw           8               ;
                    subwf           dipval,w        ;
                    goto            op8             ;
                    movlw           7               ;
                    subwf           dipval,w        ;
                    goto            op7             ;
                    movlw           6               ;
                    subwf           dipval,w        ;
                    goto            op6             ;
                    movlw           5               ;
                    subwf           dipval,w        ;
                    goto            op5             ;
                    movlw           4               ;
                    subwf           dipval,w        ;
                    goto            op4             ;
                    movlw           3               ;
                    subwf           dipval,w        ;
                    goto            op3             ;
                    movlw           2               ;
                    subwf           dipval,w        ;
                    goto            op2             ;
                    movlw           1               ;
                    subwf           dipval,w        ;
                    goto            op1             ;
                    goto            op              ;
    op              bsf             _flags,0        ;fast sweep
                    movlw           250             ;
                    movwf           temp2           ;sweep = 255
                    movlw           5               ;255 /10 th = variable rate 5
                    movwf           _lenth          ;
                    movlw           3               ;
                    movwf           temp3           ;pitch preset to 25
    siren           bsf             port_b,7        ;beeper on
                    call            pit             ;variable pitch
                    bcf             port_b,7        ;beeper off
                    decfsz          temp2,same      ;sweep timer
                    goto            var             ;
                    movlw           250             ;reset sweep timer
                    movwf           temp2           ;
                    goto            tog             ;toggle if sweep over
    tog             btfsc           _flags,0        ;test if sweep off
                    goto            down            ;pitch down
                    goto            up              ;pitch up
    down            bcf             _flags,0        ;
                    goto            siren           ;
    up              bsf             _flags,0        ;
                    goto            siren           ;
    var             decfsz          _lenth,same     ;
                    goto            siren           ;
                    btfsc           _flags,0        ;test if sweep up or down
                    goto            re              ;
                    decfsz          temp3,same      ;
                    goto            qw1             ;
                    bsf             _flags,0        ;
    qw1             movlw           5               ;reset /10      5
                    movwf           _lenth          ;
                    goto            siren           ;
    re              incf            temp3,same      ;
                    movlw           5               ;
                    movwf           _lenth          ;reset /10      5
                    goto            siren           ;
    pit             movf            temp3,w         ;
                    movwf           temp4           ;
    g               clrwdt                          ;kick dog
                    decfsz          temp4,same      ;
                    goto            g               ;
                    retlw           0               ;
    op1             bsf             _flags,0        ;very slow sweep
                    movlw           230             ;
                    movlw           3               ;255 /10 th = variable rate
                    movwf           _lenth          ;
                    movlw           85              ;
    siren1          bsf             port_b,7        ;beeper on
                    goto            var1            ;
                    movlw           230             ;reset sweep timer
                    movwf           temp2           ;
                    goto            tog1            ;toggle if sweep over
    tog1            btfsc           _flags,0        ;test if sweep off
                    goto            down1           ;pitch down
                    goto            up1             ;pitch up
    down1           bcf             _flags,0        ;
                    goto            siren1          ;
    up1             bsf             _flags,0        ;
                    goto            siren1          ;
    var1            decfsz          _lenth,same     ;
                    goto            siren1          ;
                    goto            re1             ;
                    decf            temp3,same      ;
                    movlw           3               ;reset /10
                    movwf           _lenth          ;
                    goto            siren1          ;
    re1             incf            temp3,same      ;
                    movlw           3               ;
                    goto            siren1          ;
    op2             bsf             _flags,0        ;medium sweep
                    movlw           10              ;
    siren2          bsf             port_b,7        ;beeper on
                    goto            var2            ;
    var2            btfsc           _flags,0        ;test if sweep up or down
                    goto            re2             ;
                    decfsz          temp3,same      ;
                    goto            siren2          ;
                    bsf             _flags,0        ;
                    incf            temp3,same      ;
                    goto            siren2          ;
    re2             incf            temp3,same      ;
                    movlw           150             ;
                    subwf           temp3,w         ;
                    btfsc           _status,_carry  ;set if pos
                    bcf             _flags,0        ;
                    goto            siren2          ;
    op3             bsf             _flags,0        ;police siren
                    movlw           5               ;sweep delay timer
                    movwf           temp1           ;
                    movlw           255             ;
                    movlw           255             ;
    siren3          bsf             port_b,7        ;beeper on
                    decfsz          temp1,same      ;delay sweep
                    goto            siren3          ;
                    movlw           5               ;reset delayed sweep
                    movwf           temp1           ;
                    btfsc           _flags,0        ;test if up or down sweep
                    goto            m1              ;
                    goto            m2              ;
    m1              decfsz          temp2,same      ;sweep timer
                    goto            var3            ;
                    goto            tog3            ;toggle if sweep over
    m2              movlw           5               ;
                    subwf           temp2,same      ;
                    movf            temp2,w         ;
                    btfsc           _status,_zero   ;
                    goto            var3            ;
    tog3            btfsc           _flags,0        ;test if sweep off
                    goto            down3           ;pitch down
                    goto            up3             ;pitch up
    down3           bcf             _flags,0        ;
                    goto            siren3          ;
    up3             bsf             _flags,0        ;
                    goto            siren3          ;
    var3            btfsc           _flags,0        ;test if sweep up or down
                    goto            re3             ;
                    decf            temp3,same      ;
                    goto            siren3          ;
    re3             movlw           255             ;
                    subwf           temp3,w         ;
                    btfsc           _status,_carry  ;set is positive
                    bcf             _flags,0        ;
                    incf            temp3,same      ;
                    goto            siren5          ;
    op4             bsf             _flags,0        ;slow rise
                    movlw           6               ;sweep delay timer
                    movwf           temp1           ;
                    movlw           255             ;
                    movlw           255             ;
    siren4          bsf             port_b,7        ;beeper on
                    goto            siren4          ;
                    movlw           6               ;reset delayed sweep
                    movwf           temp1           ;
                    btfss           _flags,0        ;test if up or down sweep
                    goto            m3              ;
                    goto            m4              ;
    m3              decfsz          temp2,same      ;sweep timer
                    goto            var4            ;
                    goto            tog4            ;toggle if sweep over
    m4              movlw           5               ;
                    subwf           temp2,same      ;
                    movf            temp2,w         ;
                    goto            var4            ;
    tog4            btfsc           _flags,0        ;test if sweep off
                    goto            down4           ;pitch down
                    goto            up4             ;pitch up
    down4           bcf             _flags,0        ;
                    goto            siren4          ;
    up4             bsf             _flags,0        ;
                    goto            siren4          ;
    var4            btfsc           _flags,0        ;test if sweep up or down
                    goto            re4             ;
                    decf            temp3,same      ;
                    goto            siren4          ;
    re4             movlw           255             ;
                    subwf           temp3,w         ;
                    bcf             _flags,0        ;
                    incf            temp3,same      ;
                    goto            siren5          ;
    op5             bsf             _flags,0        ;ultra low sweep (air raid)
                    movlw           20              ;sweep delay timer
                    movwf           temp1           ;
                    movlw           255             ;
                    movlw           255             ;
    siren5          bsf             port_b,7        ;beeper on
                    goto            siren5          ;
                    movlw           20              ;reset delayed sweep
                    movwf           temp1           ;
                    goto            var5            ;
                    goto            tog5            ;toggle if sweep over
    tog5            btfsc           _flags,0        ;test if sweep off
                    goto            down5           ;pitch down
                    goto            up5             ;pitch up
    down5           bcf             _flags,0        ;
                    goto            siren5          ;
    up5             bsf             _flags,0        ;
                    goto            siren5          ;
    var5            btfsc           _flags,0        ;test if sweep up or down
                    goto            re5             ;
                    decf            temp3,same      ;
                    goto            siren5          ;
    re5             movlw           255             ;
                    subwf           temp3,w         ;
                    bcf             _flags,0        ;
                    incf            temp3,same      ;
                    goto            siren5          ;
    op6             bsf             _flags,0        ;two tone high pitch
                    movlw           2               ;sweep delay timer
                    movwf           temp1           ;
                    movlw           255             ;
                    movlw           50              ;
    siren6          bsf             port_b,7        ;beeper on
                    goto            siren6          ;
                    movlw           2               ;reset delayed sweep
                    movwf           temp1           ;
                    goto            siren6          ;
                    btfsc           _flags,0        ;test if high or low
                    goto            m5              ;
                    goto            m6              ;
    m5              movlw           20              ;
                    movwf           temp3           ;
                    bcf             _flags,0        ;
                    goto            siren6          ;
    m6              movlw           50              ;
                    movwf           temp3           ;
                    bsf             _flags,0        ;
                    goto            siren6          ;
    op7             bsf             _flags,0        ;continues
                    movlw           40              ;
    siren7          bsf             port_b,7        ;beeper on
                    goto            siren7          ;
    op8             movlw           40              ;telephone
                    movlw           100              ;
                    movwf           _lenth          ;lenth timer
    siren8          bsf             port_b,7        ;beeper on
                    goto            siren8          ;
                    movlw           100             ;reset lenth timer
                    movwf           _lenth          ;
                    movlw           50              ;
    siren9          bsf             port_b,7        ;beeper on
                    goto            siren9          ;
                    movwf           _lenth          ;
                    goto            op8             ;
    op9             movlw           40              ;buzzer
                    movlw           2               ;
    siren10          bsf             port_b,7       ;beeper on
                    goto            siren10         ;
                    movlw           2               ;reset lenth timer
                    movwf           _lenth          ;
                    movlw           255             ;
    siren11         bsf             port_b,7        ;beeper on
                    goto            siren11         ;
                    movwf           _lenth          ;
                    goto            op9             ;
    op10            bsf             _flags,0        ;laser shoot fast
                    movlw           1               ;sweep delay timer
                    movwf           temp1           ;
                    movlw           255             ;
                    movlw           255             ;
    siren12         bsf             port_b,7        ;beeper on
                    goto            siren12         ;
                    movlw           1               ;reset delayed sweep
                    movwf           temp1           ;
                    goto            m11             ;
                    goto            m12             ;
    m11             decfsz          temp2,same      ;sweep timer
                    goto            var11           ;
                    goto            tog13           ;toggle if sweep over
    m12             movlw           5               ;
                    subwf           temp2,same      ;
                    movf            temp2,w         ;
                    goto            var11            ;
    tog13           btfsc           _flags,0        ;test if sweep off
                    goto            down13          ;pitch down
                    goto            up13            ;pitch up
    down13          bcf             _flags,0        ;
                    goto            siren12         ;
    up13            bsf             _flags,0        ;
                    goto            siren12         ;
    var11           btfsc           _flags,0        ;test if sweep up or down
                    goto            re13            ;
                    decf            temp3,same      ;
                    goto            siren12         ;
    re13            movlw           255             ;
                    subwf           temp3,w         ;
                    bcf             _flags,0        ;
                    incf            temp3,same      ;
                    goto            siren12         ;
    op11            bsf             _flags,0        ;laser shoot slow
                    movwf           temp1           ;
                    movlw           255             ;
                    movlw           255             ;
    siren13         bsf             port_b,7        ;beeper on
                    goto            siren13         ;
                    movwf           temp1           ;
                    goto            m13             ;
                    goto            m14             ;
    m13             decfsz          temp2,same      ;sweep timer
                    goto            var13           ;
                    goto            tog14           ;toggle if sweep over
    m14             movlw           5               ;
                    subwf           temp2,same      ;
                    movf            temp2,w         ;
                    goto            var13            ;
    tog14           btfsc           _flags,0        ;test if sweep off
                    goto            down14          ;pitch down
                    goto            up14            ;pitch up
    down14          bcf             _flags,0        ;
                    goto            siren13         ;
    up14            bsf             _flags,0        ;
                    goto            siren13         ;
    var13           btfsc           _flags,0        ;test if sweep up or down
                    goto            re14            ;
                    decf            temp3,same      ;
                    goto            siren13         ;
    re14            movlw           255             ;
                    subwf           temp3,w         ;
                    bcf             _flags,0        ;
                    incf            temp3,same      ;
                    goto            siren13         ;
    op12            bsf             _flags,0        ;continues pulsed
                    movlw           40              ;
                    movlw           255             ;pulse timer
                    movwf           temp5           ;
    siren14         bsf             port_b,7        ;beeper on
                    decfsz          temp5,same      ;
                    goto            siren14         ;
    qw3             clrwdt                          ;kick dog
                    call            pit             ;
                    decfsz          temp5,same      ;
                    goto            qw3             ;
                    decfsz          temp3           ;
                    goto            qw3             ;
                    goto            op12            ;
    op13            bsf             _flags,0        ;double sweep fast
                    movlw           200             ;
    siren15         bsf             port_b,7        ;beeper on
                    decfsz          temp3,same      ;
                    goto            siren15         ;
                    movlw           200             ;
                    movwf           temp3           ;
                    goto            siren15         ;
    op14            bsf             _flags,0        ;
                    movlw           10              ;
    siren16         bsf             port_b,7        ;beeper on
                    movlw           1               ;
                    addwf           temp3,same      ;
                    goto            siren16         ;
                    org             3ffh            ;
                    goto            init            ;
                    END                             ;
    Aug 2003
    For 16F84 there’s an excuse for that, but wouldn’t it be easier for 16F628 to use hardware PWM
    and have your software just adjust the registers?
    I don’t see any benefit worrying about assembler for that.
  1. Police Siren like Barricade has?
    By DanPBP in forum Off Topic
    Last Post: - 4th June 2016, 21:28
  2. intervall timer siren
    By oeloeg in forum mel PIC BASIC Pro
    Last Post: - 7th August 2011, 17:46
  3. TMR0 as counter
    Last Post: - 31st March 2009, 20:34
  4. Tmr0
    By laughing-gravy in forum mel PIC BASIC
    Last Post: - 19th February 2007, 20:51
  5. Sound and sound control with minimal parts
    By bartman in forum General
    Last Post: - 18th January 2005, 15:08
