different sampleus time for three ADCs
Results 1 to 11 of 11
    Nov 2015
    Default different sampleus time for three ADCs
    I've seen the manual and suggest to use DEFINE ADC_SAMPLEUS X
    but when I need different values for them, in my case 10000 for ADC1 and 1000000 for ADC2 AND ADC3, How can I do it if there is only one sampleus definition?
    I suppose this don't interfere with interrupt clock operations or any retard to the program.
    Thank you in advance
    Luis
    Default Re: different sampleus time for three ADCs
    it's so easy to use the ADCs directly it hardly worth using the built-in ADC functions. In this case I guess in this case you have to.
    George
    Nov 2015
    So nobody there knows how to use different sampleus times for several ADCs on 18F4550 or any other with several ADCs? I'm using picbasic pro.
    DEFINE is a compile time directive so it can not be used to change stuff at runtime. I don't know how ADCIN works under the hood, ie if it's simply adding a PAUSUS for the duration of the sampletime or if it's actually setting acqusition time select bits of the ADC (which on the 18F4550 is in the ADCON2 register.)
    If you need to change the acqusition time during runtime you're better off driving the ADC manually - which I believe you've received as an answer already.
    Read chapter 21 in the datasheet a couple of times. It explains how to calculate the minimum conversion clock cycle time (TAD) as well as the minium acquisition time (TAcq). The acquisition time is derived from the TAD so you need to choose a TAD which allows for a long enough acqusition time.
    "So nobody there knows how to use different sampleus times for several ADCs on 18F4550 or any other with several ADCs? I'm using picbasic pro. "
    Well, For starters, there is only 1 10 bit A/D converter on board the PIC in question. Second thing is why would you want to change the sampling time? Are you changing the oscillator frequency? If the oscillator frequency is the same for all operations then, look at the data sheet and set the DEFINE ADC_SAMPLEUS to the minimum for the oscillator frequency being used. That way you get the quickest A/D settling time and quickest A/D conversion.
    EN82fn
    Aug 2011
    I wonder if the OP is confusing the sample time with some sort of automatic period for reading the ADC? The times he's mentioning are way too long for just the sampling delay after changing the channel.
    Nov 2015
    As you can see, I'm new to this.
    Since I'm using Pic Basic Pro, I use ADCIN and sampleus time
    What I want is to get ADCIN 0 each time required for the program (velocitiy), and ADCIN 1 and ADCIN 2 each two seconds alternatively, because they are temperature measurements that I don't need in a shorter frecuency, so I would preffer to have ADC in a mode that don't use procesor time. I was thinking on something like @ ADCON0.1=0 (go/done bit) to stop it when no needed, and start it again later, but then I was asking myself if the ADC simple works without interfering with the rest of the program when I don't use ADCIN. I don't know. I hope somebody knows that.
    The original though was that the sampleus time could determine this 2 second periods alternated, 4 seconds each, although I think now that sampleus can be short and the time to get the readings be determined by program as the example below.
    My concernings are two:
    1. The ADC could use a lot of procesor time or worst: that it breaks the USB connection I'll have
    2. That a big sampleus time be the one taking the procesor time
    ' THIS TAKES TIME FROM TICS ONLY FIRST TIME
    if banderaTpoini=0 then ' bit solo la primera vez toma tiempo
    tpoini=centesimas1 ' word
    banderaTpoini=1
    ' THIS ADD THE TIME BETWEEN READINGS
    if banderaSumarRet=0 then ' bit, suma retardo para tomar temperatura
    activarADTemp = retardoTomarTemp + tpoini 'word
    ' IF OVERFLOW COUNTER
    suma= activarADTemp ' word, ComparaT
    if suma >= maxT1 then ' 4000 sobrado para tmpos máq. una v. Word
    activarADTemp= suma - maxT1 '
    ' En declaraciones
    temp=0 ' bit
    dejar un define sampleus chico, tal vez 100
    ' IF TIME NOW, ALTERNATE READINGS
    if centesimas1>= activarADTemp then
    if temp=0 then
    temp=1
    ADCIN1 ' HERE READING AND MORE CODE
    temp=0
    ADCIN2 ' HERE READING AND MORE CODE
    tpoini= centesimas1
    banderaSumarRet=0
    ' ¿Apaga AD Go/done? Sería con @ ADCON0.1=0 y reponerlo antes de ADCIN 'HERE SHUT DOWN ADC
    ' I WOULD PUT IT ON BEFORE READING
    THANK YOU VERY MUCH FOR YOUR COMMENTS
  1. PIC 18F1330 - first time, hard time - blink that LED
    Last Post: - 1st March 2015, 22:33
  2. How best to time a pin state for extended periods of time
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 10th March 2011, 11:20
  3. DS1904 RTC - How to Convert Binary Time into Real Time/Date?
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2010, 10:45
  4. ADCIN Sampleus time question
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 17th February 2009, 18:28
  5. Linx RF -> HSERIN time delay / time critical app...
    By batee in forum mel PIC BASIC Pro
    Last Post: - 15th October 2004, 15:04
