PWM and MEMORY
Results 1 to 34 of 34
Thread: PWM and MEMORY
    Oct 2009
    Utah, USA
    Default Re: PWM and MEMORY
    you only need the "endif" if the "if" statement takes up more than one line...
    IF A=B THEN dosomething
    versus...
    IF A=B THEN
    dosomething
    IF B>A THEN
    dosomethingelse
    ENDIIF
    And as far as your question to Jersen...
    It looks to me that he is just having the code check the stored value in EE memory only on power up (or after a reset).
    You would not need to keep checking the stored value in EE every time the program loops
    You only wanted to retrieve the last stored value on power up so it does not need to be in the Main block.
    check the PBP manual for the IF statement...
    5.35 IF..THEN
    IF Comp {AND/OR Comp...} THEN Label
    IF Comp {AND/OR Comp...} THEN Statement...
    Statement...
    {ELSEIF Comp {AND/OR Comp...} THEN
    Statement...}
    {ELSE
    Statement...}
    hope this helps
    dwight
    Nice lab!!
    lets see the other half (or is that where all the dead bodies are)
    Dwight
    Apr 2016
    Plainfield, Illinois
    thanks Dwight - do the commands above the main only happen once? - I thought once it hits main and we loop on main that it doesn't occur again - we read then the value only once.
    Obvious answer maybe - ...
    My dad never liked you...
  1. Replies: 1
    Last Post: - 4th March 2013, 21:57
  2. Replies: 11
    Last Post: - 17th August 2010, 16:45
  3. Memory use - how much do you use?
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 10th June 2009, 22:39
  4. Replies: 4
    Last Post: - 2nd March 2007, 06:12
  5. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 18:38
