12Bit ADC with PIC18F2523
Results 1 to 9 of 9
    Apr 2008
    Default 12Bit ADC with PIC18F2523
    Hello,
    I have code for 10 bit ADC which is normally working with PIC18F2455 and I want to use this code for 12 bit ADC with PIC18F2523.
    I changed Define ADC_BITS 10 to ADC_BITS 12, but results are sill 10 Bits.
    I using 20 MHz external oscillator.
    How to configure this code for 12 bit ADC with PIC18F2523 ?
    Thank you
    Here is my code:
    Define LOADER_USED 1
    DEFINE OSC 48
    Define LCD_DREG PORTB
    Define LCD_DBIT 4
    Define LCD_RSREG PORTC
    Define LCD_RSBIT 7
    Define LCD_EREG PORTC
    Define LCD_EBIT 6
    DEFINE LCD_BITS 4 ' 4-bit data bus
    DEFINE LCD_LINES 2 ' LCD - 2 lines
    ' Define ADCIN parameters
    Define ADC_BITS 12 ' Set number of bits in result
    adval var word ' Create adval to store result
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 = %00001010 ' Set PORTA analog...
    ADCON2 = %10000000 ' ...and right justify result
    Pause 500 ' Wait .5 second
    loop: ADCIN 0, adval ' Read channel 0 to adval
    Lcdout $fe, 1 ' Clear LCD
    Lcdout "Value: ", DEC adval ' Display the decimal value
    Pause 100 ' Wait .1 second
    Goto loop ' Do it forever
    Default Re: 12Bit ADC with PIC18F2523
    how many times do we see this totally wrong statement
    ADCON2 = %10000000 ' ...and right justify result and set the conversion clock to fosc/2
    which is way out of limits for a 48mhz osc and contradicts the define
    why not just
    ADCON2.7=1
    or
    ADCON2 = ADCON2 | %10000000 ' ...and right justify result
    other than that i have nothing , never tried a 12 bit adc chip.
    you may need to do it manually
    Apr 2008
    Hello richard,
    I configured my code for 12 Bit AD, now I get 12 Bits results, but it is working only with 4MHz external oscillator.
    When I replace extenal oscillator wit 20MHz and DEFINE OSC 20, it is not working, what is wrong?
    Define LCD_DBIT 4
    Define LCD_RSBIT 7
    Define LCD_EBIT 6
    advalLow VAR WORD ' make it available to use in PBP
    advalHigh VAR WORD ' make it available to use in PBP
    advalLow = ADRESL
    advalHigh = ADRESH
    ADCON2.7=1 ' ...and right justify result
    adval = ADRESL + (ADRESH * 256)
    in what way does it not work ?
    where and what are your config settings
    advalLow and advalHigh only need to be bytes
    advalLow VAR byte ' make it available to use in PBP
    advalHigh VAR byte ' make it available to use in PBP
    since ADRESH and ADRESHL are sequential in memory for that chip its possible to save a bit of typing by :-
    @my_adresult =ADRESHL
    my_adresult var word ext
    ADCIN 0, adval ' Read channel 0 to dummy adval
     adval = my_adresult
    Apr 2008
    Ok,
    I directly saving the ADRESL and ADRESH register which is used to store the end results of an analog-to-digital conversion (ADC) to results adval and sending LCD. My problem is, the code is working properly only with 4MHz oscillator, when I define 20MHz occillator, the conversion is very slow, waiting few second, when start conversion.
    Whay the conversion is fast for 4Mhz oscillator and very slow for 20MHz oscillator
    and sending LCD
    where and what are your config settings ?
    the default osc is 1mhz which may be the problem
  1. ADC values above 4095 for 12 bit ADC
    Last Post: - 1st February 2015, 22:24
  2. 12bit Power Supply
    By ztoti in forum Adverts
    Last Post: - 15th October 2014, 23:29
  3. 6ch 12bit adc pic16c771
    By pigglet in forum Adverts
    Last Post: - 23rd September 2012, 15:37
  4. ADC problem on 18F46K22 device using all 28 ADC pins
    By JimAvanti in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2012, 20:22
  5. PIC18f2423 two 12bit adc input problems
    By Brandon in forum mel PIC BASIC Pro
    Last Post: - 16th December 2007, 09:47
