Multi-Button CSM with Pic16LF722A
Results 1 to 32 of 32
Threaded View
  1. #7
    Default Re: Multi-Button CSM with Pic16LF722A
    There is a "pause 300" that you have in the MAIN program area that delays the led indicator change from the time that the button is pressed. I tried to move the code
    the pause is there to slow the key action to human speeds ,the indicator leds can go in the key pressed loop ok as far as I can see
    What is "if PW.15 then PW=0" doing? Is it checking bit 15 of PW to be high?
    with any subtraction if the result is negative (ie overflowed) then the highest order bit of the result is always set.
    ps can porta.3 be an output ?
    have a try like this
    '#DEFINE DBUG 1
     __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDTE_OFF & _BOR_OFF & _PLLEN_ON
     define OSC 4
     include "dt_ints-14.bas"
     include "REENTERPBP.bas"
     ' variables used by interrupt handler, comment out as per assembler
     wsave VAR BYTE $20 SYSTEM ' location for W if in bank0
     'wsave VAR BYTE $70 SYSTEM ' alternate save location for W
     ' Comment them out to fix the problem ----
     wsave1 VAR BYTE $A0 SYSTEM ' location for W if in bank1
     'wsave2 VAR BYTE $120 SYSTEM ' location for W if in bank2
     'wsave3 VAR BYTE $1A0 SYSTEM ' location for W if in bank3
     asm
     INT_LIST macro
     INT_HANDLER T1GATE_INT, _TB1, PBP,YES
     INT_CREATE
     THRESH CON 16000 'needs to be established
     FLG VAR BYTE 'GOT A KEY
     KP VAR BYTE 'WHICH KEY pressed
     key_inx var byte ;key index
     PW VAR WORD ;PULSEWIDTH
     p_level var byte
     DEFINE DEBUG_REG PORTB
     DEFINE DEBUG_BIT 7 ;pgd
     DEFINE DEBUG_BAUD 9600
     DEFINE DEBUG_MODE 0
     OSCCON = %00010000 '4 mhz
     CPSCON0 = %10001100 'high range
     CPSCON1 = 0 'cps ch 0
     ANSELB = %00000111 'SETS INPUTS B0-B2 AS ANALOG
     TRISB = %01111111 'SETS INPUTS B0-B5 AS INPUTS b7 output
     WPUB = %00000000 'DISABLES WEAK PULL-UP BITS
     TRISC = %11111011 'ccp1 output portc.2
     OPTION_REG=$86 'edge int. prescale 1:128
     PIE1.7=1 'timer1 gate interrupt
     T1GCON=$f9 'single shot timer0 overflow as input
     T1CON=%11000101 'capsense as input no prescale no sync
     INTCON= $C0 'peripheral interrupts
     PW=1023
     p_level=5
     t2con=7
     LED1 VAR PORTA.1 ' SET LED LEVEL INDICATORS
     LED2 VAR PORTA.2
     LED3 VAR PORTA.3  ;?????????????????????????????????
     LED4 VAR PORTA.4
     LED5 VAR PORTA.5
     LED VAR portc.2
     ;up down off
     ;key0=portb.0=ch0, key1=portb.1=ch1, key2=portb.2=ch2
     #IFDEF DBUG
     portb.7=1
     LED=1
     pause 2000
     Debug "Start",13 ,10
     LED=0
     #ENDIF
     ccp1con=12
     CCPR1L=255 'SET TO MAX BRIGHTNESS
     FLG=0
     key_inx=0
     MAIN:
     IF FLG=1 THEN
     IF KP = 0 THEN '1/0 BUTTON PRESSED
     ccp1con=0 ;kill it
     led=0
     p_level=0
     ELSEif KP = 1 THEN 'UP BUTTON PRESSED
     p_level= (p_level+1) min 5
     ;PW= (PW+256) MIN 1023
     else 'DOWN BUTTON PRESSED
     p_level= p_level-1
     ;PW = PW-256
     IF p_level.7 THEN p_level=0
     ;IF PW.15 THEN PW=0
     lookup p_level, [0,12,48,218,586,1023],pw  'gamma 1.35,5 levels plus OFF
     CCPR1L = PW>>2;
     ccp1con=12|((PW&3)<<4);
     #IFDEF DBUG
     debug "KEY ",#KP,13,10
     debug #PW,13,10
     #ENDIF
     PAUSE 300
     FLG=0 'clr key pressed flag
     porta=0  ;all leds off
     IF p_level= 5 THEN
     HIGH LED5
     IF p_level=4 THEN
     HIGH LED4
     IF p_level=3 THEN
     HIGH LED3
     IF p_level=2 THEN
     HIGH LED2
     if p_level=1 THEN
     high LED1
     GOTO MAIN
     TB1:
     #IFDEF DBUG
     debug #TMR1,13,10
     #ENDIF
     IF TMR1 < THRESH THEN ' KEY DETECTED
     if !flg then
     KP=key_inx
     FLG=1 'set key pressed flag
     key_inx=key_inx+1 ;check next key
     if key_inx > 2 then key_inx=0
     CPSCON1 = key_inx
     TMR1=0
     T1GCON.3= 1 ;single shot reset
     @ INT_RETURN
  1. Replies: 5
    Last Post: - 18th March 2012, 21:40
  2. multi functions button press
    By malwww in forum mel PIC BASIC Pro
    Last Post: - 27th May 2009, 00:12
  3. Multi-Threading
    By Ted's in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 05:55
  4. Multi-tasking
    Last Post: - 13th July 2006, 18:50
  5. Multi Interrupt How To ?
    By capitano in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2005, 14:48
Members who have read this thread : 4
