Multi-Button CSM with Pic16LF722A
Results 1 to 32 of 32
    Apr 2016
    Mi, USA
    Default Re: Multi-Button CSM with Pic16LF722A
    Hello again!
    If I want to change the order of the keys so that key0 = 1/0 (RB2), key1 = down(RB1), and key2 = up(RB0) do I need to un-remark the
    ;key0=portb.0=ch0, key1=portb.1=ch1, key2=portb.2=ch2 statement and change it, or do I need to change the code in the main portion of the program?
    Is there any way I can get the 1/0 button to toggle between off and full pwm, right now I am only getting a momentary break in the pwm when it is touched.
    In the debug setup, all I need to do is monitor the pin specified with Serial Communicator or Hyperterminal?
    I still can't believe how simple you made this look compared to my listing posted above. Thanks again!
    comments are just that ,they only serve to show what it is that the programmer decides need an explanation . they don't get compiled or participate in the execution of the code in any way. to change the way the keys are interpreted requires a change the code .
    my mistake the pw var should also be set to zero too when killing the light
    I use a pickit2 to pgm/debug with ,the debug statements suit my setup . if you use a real rs232 port to debug then a rs232/ttl level converter needs to be used and the logic level may need to be inverted [rtfm]
    should be easy , hint "FINITE STATE MACHINE"
    what did your "threshold" count need to be ?
    why not explore a "limited slew rate filter" to automatically track and adjust the threshold value . or more reliable yet, automatically track and adjust the threshold value for each individual key
    Apr 2016
    Mi, USA
    Thanks for the info. Right now I am using 16000 as a threshold, and it seems to be working well. I have a pickit2, maybe I'll try that. I also have a usb to serial in both 3v and 5v versions. I've been looking at the Microchip application notes concerning touch applications and ran across what you are talking about concerning the threshold value for each key. Maybe once I get into the debugging, I can determine if I will need to do more than a fixed threshold. Thanks again!
    There is a "pause 300" that you have in the MAIN program area that delays the led indicator change from the time that the button is pressed. I tried to move the code
    the pause is there to slow the key action to human speeds ,the indicator leds can go in the key pressed loop ok as far as I can see
    What is "if PW.15 then PW=0" doing? Is it checking bit 15 of PW to be high?
    with any subtraction if the result is negative (ie overflowed) then the highest order bit of the result is always set.
    ps can porta.3 be an output ?
    have a try like this
    '#DEFINE DBUG 1
     __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDTE_OFF & _BOR_OFF & _PLLEN_ON
     define OSC 4
     include "dt_ints-14.bas"
     include "REENTERPBP.bas"
     ' variables used by interrupt handler, comment out as per assembler
     wsave VAR BYTE $20 SYSTEM ' location for W if in bank0
     'wsave VAR BYTE $70 SYSTEM ' alternate save location for W
     ' Comment them out to fix the problem ----
     wsave1 VAR BYTE $A0 SYSTEM ' location for W if in bank1
     'wsave2 VAR BYTE $120 SYSTEM ' location for W if in bank2
     'wsave3 VAR BYTE $1A0 SYSTEM ' location for W if in bank3
     asm
     INT_LIST macro
     INT_HANDLER T1GATE_INT, _TB1, PBP,YES
     INT_CREATE
     THRESH CON 16000 'needs to be established
     FLG VAR BYTE 'GOT A KEY
     KP VAR BYTE 'WHICH KEY pressed
     key_inx var byte ;key index
     PW VAR WORD ;PULSEWIDTH
     p_level var byte
     DEFINE DEBUG_REG PORTB
     DEFINE DEBUG_BIT 7 ;pgd
     DEFINE DEBUG_BAUD 9600
     DEFINE DEBUG_MODE 0
     OSCCON = %00010000 '4 mhz
     CPSCON0 = %10001100 'high range
     CPSCON1 = 0 'cps ch 0
     ANSELB = %00000111 'SETS INPUTS B0-B2 AS ANALOG
     TRISB = %01111111 'SETS INPUTS B0-B5 AS INPUTS b7 output
     WPUB = %00000000 'DISABLES WEAK PULL-UP BITS
     TRISC = %11111011 'ccp1 output portc.2
     OPTION_REG=$86 'edge int. prescale 1:128
     PIE1.7=1 'timer1 gate interrupt
     T1GCON=$f9 'single shot timer0 overflow as input
     T1CON=%11000101 'capsense as input no prescale no sync
     INTCON= $C0 'peripheral interrupts
     PW=1023
     p_level=5
     t2con=7
     LED1 VAR PORTA.1 ' SET LED LEVEL INDICATORS
     LED2 VAR PORTA.2
     LED3 VAR PORTA.3  ;?????????????????????????????????
     LED4 VAR PORTA.4
     LED5 VAR PORTA.5
     LED VAR portc.2
     ;up down off
     #IFDEF DBUG
     portb.7=1
     LED=1
     pause 2000
     Debug "Start",13 ,10
     LED=0
     #ENDIF
     ccp1con=12
     CCPR1L=255 'SET TO MAX BRIGHTNESS
     FLG=0
     key_inx=0
     MAIN:
     IF FLG=1 THEN
     IF KP = 0 THEN '1/0 BUTTON PRESSED
     ccp1con=0 ;kill it
     led=0
     p_level=0
     ELSEif KP = 1 THEN 'UP BUTTON PRESSED
     p_level= (p_level+1) min 5
     ;PW= (PW+256) MIN 1023
     else 'DOWN BUTTON PRESSED
     p_level= p_level-1
     ;PW = PW-256
     IF p_level.7 THEN p_level=0
     ;IF PW.15 THEN PW=0
     lookup p_level, [0,12,48,218,586,1023],pw  'gamma 1.35,5 levels plus OFF
     CCPR1L = PW>>2;
     ccp1con=12|((PW&3)<<4);
     #IFDEF DBUG
     debug "KEY ",#KP,13,10
     debug #PW,13,10
     #ENDIF
     PAUSE 300
     FLG=0 'clr key pressed flag
     porta=0  ;all leds off
     IF p_level= 5 THEN
     HIGH LED5
     IF p_level=4 THEN
     HIGH LED4
     IF p_level=3 THEN
     HIGH LED3
     IF p_level=2 THEN
     HIGH LED2
     if p_level=1 THEN
     high LED1
     GOTO MAIN
     TB1:
     #IFDEF DBUG
     debug #TMR1,13,10
     #ENDIF
     IF TMR1 < THRESH THEN ' KEY DETECTED
     if !flg then
     KP=key_inx
     FLG=1 'set key pressed flag
     key_inx=key_inx+1 ;check next key
     if key_inx > 2 then key_inx=0
     CPSCON1 = key_inx
     TMR1=0
     T1GCON.3= 1 ;single shot reset
     @ INT_RETURN
    Apr 2016
    Mi, USA
    Hello again,
    Okay I got the buttons to work as i wished, and I changed to 4 pwm levels. However, I have added code to indicate which of the 4 levels I am currently at.
    There is a "pause 300" that you have in the MAIN program area that delays the led indicator change from the time that the button is pressed. I tried to move the code for the led indicators to a point before the "pause 300", but then the program quits working. Is this pause what determines the time between steps if a[ button is continuously pressed, or does it serve another purpose? Another dumb thing, if I want 5 levels plus off, as shown in my previously posted example, how do I do it? Currently I am using a value of 256 from the original 16 as you had to get 4 steps, but that works out pretty evenly.
    What is "if PW.15 then PW=0" doing? Is it checking bit 15 of PW to be high? Please see cod attached.
    Thanks.
    [CODE'********************************************* *******************
    '* Name : CAPSENSE.BAS *
    '* Author : RICHARD *
    '* Notice : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 10/20/2011 *
    '* Version : 1.0 *
    '* Notes : *
    '* : 16LF722A *
    '#DEFINE DBUG 1
    define OSC 4
    asm
    INT_LIST macro
    INT_CREATE
    DEFINE DEBUG_MODE 0
    PW=1023
    t2con=7
    LED2 VAR PORTA.2
    LED3 VAR PORTA.3
    LED4 VAR PORTA.4
    LED5 VAR PORTA.5
    LED VAR portc.2
    ;up down off
    #IFDEF DBUG
    portb.7=1
    LED=1
    pause 2000
    LED=0
    #ENDIF
    ccp1con=12
    FLG=0
    key_inx=0
    MAIN:
    IF FLG=1 THEN
    ccp1con=0 ;kill it
    led=0
    PW=0
    PW = PW-256
    IF PW.15 THEN PW=0
    CCPR1L = PW>>2;
    #IFDEF DBUG
    debug #PW,13,10
    #ENDIF
    PAUSE 300
    IF pw = 1023 THEN
    HIGH LED5
    IF pw = 768 or PW = 767 THEN
    HIGH LED4
    IF pw = 512 or PW = 511 THEN
    HIGH LED3
    IF pw = 256 or PW = 255 THEN
    HIGH LED2
    if pw = 0 THEN
    high LED1
    GOTO MAIN
    TB1:
    #IFDEF DBUG
    debug #TMR1,13,10
    #ENDIF
    if !flg then
    KP=key_inx
    CPSCON1 = key_inx
    TMR1=0
    @ INT_RETURN][/CODE]
  1. Replies: 5
    Last Post: - 18th March 2012, 22:40
  2. multi functions button press
    By malwww in forum mel PIC BASIC Pro
    Last Post: - 27th May 2009, 01:12
  3. Multi-Threading
    By Ted's in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 06:55
  4. Multi-tasking
    Last Post: - 13th July 2006, 19:50
  5. Multi Interrupt How To ?
    By capitano in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2005, 15:48
Members who have read this thread : 4
