reading si7021 humy_temp sensor
Results 1 to 3 of 3
    Jun 2008
    Varese , Italy
    Default reading si7021 humy_temp sensor
    hi to all in this forum,
    Is there somebody that used the si7021 sensor with pbp please ?
    Any sample program available ?
    thanks
    Ambrogio
    Feb 2005
    brookfield, ct, usa
    Default Re: reading si7021 humy_temp sensor
    This is a program I wrote a while back to read a barometer and a humidity/temperature sensor
    Good luck
    '*  Name    : 18F45K223_HDU21D_test.pbp                                      *
    '*  Notice  : Copyright (c) 2015 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 7/21/2015                                         *
    '********************DEVICE CONFIGURATION**********************************
        CONFIG  FOSC = INTIO67        ; Internal oscillator block
        CONFIG  PLLCFG = OFF          ; Oscillator used directly
        CONFIG  PRICLKEN = OFF        ; Primary clock can be disabled by software
        CONFIG  PWRTEN = OFF          ; Power up timer disabled
        CONFIG  BOREN = SBORDIS       ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
        CONFIG  BORV = 190            ; VBOR set to 1.90 V nominal
        CONFIG  WDTEN = ON            ; WDT is always enabled. SWDTEN bit has no effect
        CONFIG  WDTPS = 32768         ; 1:32768
        CONFIG  CCP2MX = PORTC1       ; CCP2 input/output is multiplexed with RC1
        CONFIG  PBADEN = OFF          ; PORTB<5:0> pins are configured as digital I/O on Reset
        CONFIG  CCP3MX = PORTB5       ; P3A/CCP3 input/output is multiplexed with RB5
        CONFIG  HFOFST = ON           ; HFINTOSC output and ready status are not delayed by the oscillator stable status
        CONFIG  T3CMX = PORTC0        ; T3CKI is on RC0
        CONFIG  P2BMX = PORTD2        ; P2B is on RD2
        CONFIG  MCLRE = EXTMCLR       ; MCLR pin enabled, RE3 input pin disabled
        CONFIG  STVREN = ON           ; Stack full/underflow will cause Reset
    '*************************DEFINEs*******************************************
    DEFINE OSC 16 ' Tell PBP the expected systemclock frequency
    ' LCD settings
    ' Set LCD Data port
    DEFINE LCD_DREG PORTB
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 0
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTB
    ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 4
    ' Set LCD Enable port
    DEFINE LCD_EREG PORTB
    ' Set LCD Enable bit
    DEFINE LCD_EBIT 5
    ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    ' Set command delay time in us
    DEFINE LCD_COMMANDUS 1500
    ' Set data delay time in us
    DEFINE LCD_DATAUS 44
    define ADC_BITS 10
    'define ADC_SAMPLEUS 50
    define I2C_HOLD 1   'allow slave to hold bus low
    '************************ALIASES***********************************************
    'click boards - addresses from easypic7 board
    'click slot 1
    'click slot 2
    CS          var portA.5
    SCL         var portC.3
    SDA         var portC.4
    '************************Constants**********************************************
    'LCD commands
    command con $FE
    clr     con $01
    home    con $02
    line1   con $80
    line2   con $C0
    trig_temp   con $E3
    trig_RH     con $E5
    HTU21D_i2c_address con $40
    MPL3115A2_i2c_address   con $60
    control con %10100000
    '************************VARIABLES**********************************************
    adval1  Var word
    adval1_dig  var byte
    adval1_dec  var word
    adval2  var word
    adval2_dig  var byte
    adval2_dec  var word
    period  var word
    dtycycl var byte
    X   var byte    'variable for the counter
    memory  var word
    Temp    var word
    Temp1   var long
    RH      var word
    RH1     var long
    deg_F   var word
    HTU21D_i2c_address1    var byte
    MPL3115A2_i2c_address1  var byte
    P_status    var byte
    out_P_MSB   var byte
    out_P_CSB   var byte
    out_P_LSB   var byte
    out_T       var word
    Pressure    var long
    '********************INITIALIZE REGISTERS***************************************
    init:
    TrisA = %00000011
    TrisB = %00000000
    TrisC = %00010000
    TrisE = %00000001
    OSCCON = %01110010
    OSCCON2 = %00000100
    ANSELA = %00000011 'RA0, 1 analog, others digital
    ANSELB = %00000000 'all others digital
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    ADCON1 = %00001000 'AD Vre3f+ connected to FVR BUF2
    ADCON2 = %10010111 'right justified, 4Tad aquisition time, Frc clock derived from internal oscilator
    VREFCON0 = %10100000 'internal voltage refernce enabled, set to 2.048 Vdc
    CCP2CON = %00001100 'single outputP2A modulated
    ' PROGRAM CODE
    pause 1500      'allow LCD to wake up
    lcdout command, clr
    pause 20
    lcdout command, line1, "hello world"
    pause 5000
    lcdout command, clr
    pause 20
    HTU21D_i2c_address1 = HTU21D_i2c_address <<1
    MPL3115A2_i2c_address1 = MPL3115A2_i2c_address<<1
    i2cwrite SDA, SCL, HTU21D_i2c_address1, [trig_temp]
    pause 10
    i2cread SDA, SCL, HTU21D_i2c_address1, [temp]
    pause 10
    i2cwrite SDA, SCL, HTU21D_i2c_address1, [trig_RH]
    pause 10
    i2cread SDA, SCL, HTU21D_i2c_address1, [RH]
    temp.1 = 0
    Temp.0 = 0
    RH.1 = 0
    RH.0 = 0
    RH1 = rh ** 12500
    rh1 = RH1 - 600
    temp1 = temp ** 17572
    temp1 = temp1 - 4685
    deg_F = ((Temp1 *9)/5) + 3200
    lcdout command, line1, dec2 deg_F/100, ".", dec1 deg_F//100, " ", 223, "F ", dec2 RH1/100, ".", dec1 RH1//100, " %RH"
    pause 10
    i2cwrite SDA, SCL, MPL3115A2_i2c_address1, $26, [%00000011]
    pause 20
    i2cread sda, scl, MPL3115A2_i2c_address1, $00, [P_status, out_P_MSB, out_P_CSB, out_P_LSB, out_T]
    pressure = 0
    pressure.byte2 =   out_P_MSB
    pressure.byte1 =   out_P_CSB
    pressure.byte0 =   out_P_LSB
    pressure = pressure>>6
    pressure = Pressure * 10000
    pressure = pressure / 338639
    'pressure = pressure/33864
    'out_T = out_T>>3
    lcdout command, line2, dec2 pressure/100, ".",dec2 pressure//100, " in Hg"
    'lcdout command, line2, dec6 out_T, " ", 223, "C"
    pause 2000
    Jun 2008
    Varese , Italy
    thanks Alec,
    Ambrogio
  1. I can not a reading sensor lm35
    By cesar35 in forum mel PIC BASIC Pro
    Last Post: - 8th January 2016, 20:38
  2. Reading a speed sensor best method?
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 27th January 2012, 03:37
  3. Tilt Sensor Reading
    By sincity337 in forum Serial
    Last Post: - 20th September 2010, 06:23
  4. Need help for reading I2C Sensor
    By Omalik in forum Serial
    Last Post: - 10th June 2008, 05:24
  5. Reading a linear hall sensor
    By peu in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2006, 23:31
