Reading incremental encoder
Results 1 to 8 of 8
    Apr 2016
    Default Reading incremental encoder
    Hi all,
    For a university project I have written a PICBASIC code to read digital signals from the encoder on my MCU and send them to both another MCU (to graphically plot the result on PC via Python) and to an LCD screen (for debugging). Now, since i'm completely new to picbasic i have no idea whether my code will work. Since we have limited time to actually work with the hardware, we have to make sure the software is carefully prepared beforehand. That's why i would kindly ask some of you guys, with a lot more experience, to look through my code and make me aware of certain mistakes.
    The MCU i'm using is PIC12F683 (datasheet: http://akizukidenshi.com/download/ds/microchip/pic12f683.pdf). It's an 8 pin MCU.
    The encoder output (which is the MCU input) exists out of 2 square waves, which are the same but shifted 90° in phase (to check which way the encoder is turning).
    What i want to get as output is a 3 digit number, because that is what to next MCU requires as input. So i wanted to take number 0 to 499 for clockwise turning and 501 to 999 for counterclockwise turning.
    I'm pretty convinced the idea behind my method is correct, but i have no idea whether i have written it all in a correct way, without too many syntax errors.
    Here's what i've written so far, i hope i did a decent job of explaining what i want to achieve, if not you can always ask me.
    It would be great if some people with actual PICBASIC knowledge could help me
    Thanks!
    '* Name : RotaryEncoder.BAS *
    '* Author : Robbe Degezelle *
    '* Notice : Copyright (c) 2016 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 12/04/2016 *
    '* Version : 1.0 *
    '* Notes : *
    'initialisation------
    NewVal = (GPIO & 000) >> 3
    OldVal = NewVal
    ANSEL = 00000 ' all pins digital
    TRISIO = 1111 'set all ports to inputs
    'Enc_1 VAR GPIO.5 ' first encoder input
    'Enc_2 var GPIO.4 ' second encoder input
    LCD_pin var GPIO.1
    'variables-----------
    NewVal VAR BYTE
    OldVal VAR BYTE
    Counter VAR BYTE
    CounterCC var byte
    Counter = 000
    CounterCC = 500
    word1 var word 'C
    word1=000
    word2 var word 'CC
    word2=000
    P4800 CON 188 '4800 baud true
    N9600 con $4054 '9600 baud rate inverted
    'Program----------------
    Main
    NewVal = (GPIO & 000) >> 3 ; zou 0,1,2 of 3 moeten geven
    If NewVal <> OldVal Then
    Branch CurVal, [S0,S1,S2,S3] ; indien waarde veranderd, vergelijken met oud
    EndIF
    AfterBranch
    Goto Main
    S0
    If OldVal = 2 Then
    GoSub Clockwise
    GoSub CounterClockwise
    EndIF
    Goto AfterBranch
    S1
    if OldVal = 0 Then
    GoSub Clockwise
    EndIF
    Goto AfterBranch
    S2
    if OldVal = 3 Then
    GoSub Clockwise
    Else
    EndIf
    Goto AfterBranch
    S3
    if OldVal = 1 Then
    GoSub Clockwise
    Else
    GoSUb CounterClockwise
    Endif
    Goto AfterBranch
    Clockwise
    OldVal = CurVal
    Counter = Counter + 1
    word1 = Counter
    serout2 GPIO.0,p4800, ["B1", DEC3 word1]
    gosub disp_lcd
    CounterClockwise
    OldVal = CurVal
    CounterCC = CounterCC + 1
    word2 = CounterCC
    serout2 GPIO.0,p4800, ["B1", DEC3 word2]
    gosub disp_lcd
    'LCD
    disp_lcd
    serout2 LCD_pin, N9600, [$FE, 1$] 'clear display
    pause 1
    serout2 LCD_pin, N9600, [$FE, 2$] 'cursor returns home
    pause 1
    serout LCD_pin, N9600, ["TellerC= ", DEC Counter]
    pause 1
    SEROUT2 LCD_pin,N9600, [$FE, $C0] 'cursor to 2nd line
    pause 1
    SEROUT2 LCD,N9600, ["TellerCC= ", dec CounterCC]
    Default Re: Reading incremental encoder
    You have limited time to work with the hardware and you don't have time to even compile the code to see if there are any syntax errors and you want us to check for it you. Is that it? OK, here are a couple of things I noticed:
    CounterCC is declared as a BYTE but you're trying to squeeze a value of 500 into it.
    There are no colons after LABELS.
    There are no % signs where your expressing your numbers in binary.
    You're reading the state of the IO pins into NewVAL but you're using CurVal in the BRANCH statement.
    Provided the decoding logic is correct (which I haven't checked) it's not going to keep up with a turning encoder since all the SEROUT statements will take tens or even hundreds of ms each time - that may not matter, I don't know - just pointing it out.
    When posting code in the forum, please use code-tags.
    Oct 2009
    You beat me to it...
    Oct 2009
    'LCD
    disp_lcd
    pause 1
    pause 1
    pause 1
    pause 1
    OK you may of got some syntax wrong, but at least check for obvious omissions first !
    Oct 2009
    You also need to set the PIC registers and to get reliable 9600 baud rate you need to ensure the PIC is running at 4Mhz as serial out assumes a 4mhz timing base
    From the BPB manual
    SEROUT2 assumes a 4MHz oscillator when generating its bit timing. To maintain the proper baud rate timing rate with other oscillator values, be sure to DEFINE the OSC setting to the new Oscillator value. An oscillator speed faster than 4MHz may be required for reliable operation at 9600 baud and above
    You need to read section 3.5.2 of the datasheet on how to configure the internal oscillator HFINTOSC which is factory calibrated to 8Mhz, The frequency of the HFINTOSC can be altered via software using the OSCTUNE register (see the Register section 3-2).
    The point of mentioning this is that you really need to spend time developing the hardware as well as the software... the two go hand in hand.
    It may seem that we've come down hard on you, but then you must appreciate that the guys here see 100's of posts from new members who ask for help, but don't want to put the effort in from the start. The guys here (Henrik, Tabsoft and Richard to name a few) are very helpful and have lots of coding experience, and it's only fair to have done the ground work first, and then they are only too pleased to help (and I'm talking from experience here)
    Oct 2009
    Ok this compiles... but it won't work as there are lots missing from the code, such as the "afterbranch" subroutine hasn't been included (I just gave it a label and return) I've also added some config settings, and a few missing variables...
    '* Version : 1.0 *
    '* Notes : *
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BOD_ON
              ' Internal Oscillator
              ' Enable watch dog timer
              ' Enable power up timer
              ' Disable MCLR pin
              ' Enable brown out detect
    ANSEL = 0      ' Set all digital
    CMCON0 = 7     ' Analog comparators off
    LCD_pin var GPIO.1
    NewVal VAR word
    OldVal VAR word
    Counter VAR word
    CounterCC var word
    word1 var word 'C
    word2 var word 'CC
    CurVal var word '  This seemed to be missing from your original code... again I presume it should be a word variable as you have statements like OldVal = CurVal
    word2=000
    OldVal = NewVal
    Counter = 000
    CounterCC = 500
    word1=000
    EndIF
    goto AfterBranch
    Goto Main
    S0:
    If OldVal = 2 Then
    GoSub Clockwise
    EndIF
    Goto AfterBranch
    S1:
    if OldVal = 0 Then
    GoSub Clockwise
    EndIF
    Goto AfterBranch
    S2:
    if OldVal = 3 Then
    GoSub Clockwise
    Else
    EndIf
    Goto AfterBranch
    S3:
    if OldVal = 1 Then
    GoSub Clockwise
    Else
    Endif
    Goto AfterBranch
    Clockwise:
    OldVal = CurVal
    word1 = Counter
    gosub disp_lcd
    CounterClockwise:
    OldVal = CurVal
    word2 = Countercc
    gosub disp_lcd
    'LCD
    disp_lcd:
    serout2 LCD_pin, N9600, [$FE, $1] 'clear display
    pause 1
    serout2 LCD_pin, N9600, [$FE, $2] 'cursor returns home
    pause 1
    serout2 LCD_pin, N9600, ["TellerC= ", DEC Counter]
    pause 1
    pause 1
    SEROUT2 LCD_pin,N9600, ["TellerCC= ", dec CounterCC] ' corrected this line
    AfterBranch:             ' no idea what afterbranch is meant to do, as you have several goto's afterbranch but there is no such subroutine
    There may be other coding errors, but the syntax seems OK and like I said this now compiles, but until you add the missing subroutines, and take on board some of the comments Henrik has mentioned it won't work. Also, your post seemed to have good command of the English language, but some of the comments (hi-lighted in green) are in a different language, which makes me wonder if the code is your own work ?
    Oct 2009
    Well it fails to compile, and I presume that you are using PBP2.6x rather than 3.x
    To be honest, you will learn a lot more, and gain a better understanding by actually downloading the relevant software such as micro code studio, mplab etc and debug the code until it compiles without errors. You don't need the physical hardware as at this stage all you want to do is to know if the code has no errors. But, having said that, the only real way you will know if the project functions correctly is to either use an expensive simulator that runs the hex code, or get a solderless breadboard and build the circuit and debug both hardware and software at the same time
  1. Reading incremental encoder interupt
    Last Post: - 1st March 2017, 12:50
  2. Using an incremental rotary encoder?
    By keithv in forum mel PIC BASIC Pro
    Last Post: - 12th January 2016, 22:23
  3. Encoder velocity....
    By thasatelliteguy in forum mel PIC BASIC Pro
    Last Post: - 21st April 2014, 00:33
  4. Rentron Encoder
    Last Post: - 27th June 2013, 07:28
  5. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 21:56
