bootloader that xfers code from I2C into program memory
Results 1 to 31 of 31
Threaded View
  1. #22
    Sep 2009
    Default Re: bootloader that xfers code from I2C into program memory
    I did, but via EEPROM and other way. So main app knows when it is first run, so it can configure I2C memory, etc...
    But you can define variables at specific addresses.
    From manual:
    wsave VAR BYTE $70 'Creates "wsave" at RAM address 0x70 (hex)
    Just create variable at address $70 both in main app and bootloader. And load it in main app before jumping to bootloader, and use it in bootloader. But you must be careful not to clear it, before use.
    BLOCK_SIZE is ASM constant for each pic. And it tell how long is one block or page in FLASH.
    So to get this information to PBP, I used this code:
    @ MovLW BLOCK_SIZE ;move literal to W
    @ MovWF BlockSize ;Move W to File(variable)
    If variable is not defined as system
        BlockSize       VAR BYTE BANKA
        @ MovLW BLOCK_SIZE
        @ MovWF _BlockSize
    BANKA must be used, or in ASM you need to set correct bank.
    This can be done in few ways, but i don't like that. All my ASM routines use variables in BANKA, so I doesn't have to deal with selecting bank.
    SYSTEM just removes underscore in ASM variable name. Default behavior of PBP is to put _ in front of name. Eg if you declare A var byte, in ASM variable is called _A. With modifiers SYSTEM PBP will create same name for ASM.
    Just habit that I have to put all ASM variables to BANKA SYSTEM...
    [EDIT]This also could be done with EXT modifier.[/EDIT]
    FLASH is erased and write ONE PAGE at TIME. PBP will track address that you are writing, and when it align with page it will dump all data to FLASH.
    Data are temporally stored to TBL. So if you just put one WRITECODE instruction, your byte or word wont be written to FLASH. It took me some while to get it. At least for PIC18F.
    If you measure how much time it takes to do instruction WRITECODE, you will see eg 63 very fast(10-20 uS, depending on oscillator speed), and 64th will take about 5mS(doesn't depend on oscillator). This is if your page size is 64 byte. Don't hold me to exact figures, I can remember just ballpark value.
  1. Program Code and Program Memory
    By DenFrod in forum mel PIC BASIC Pro
    Last Post: - 8th February 2007, 15:51
  2. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 19:38
  3. using Flash Program Memory ?
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 11th October 2006, 16:17
  4. PIC16F88, Bootloader & I2C Memory
    By digilord in forum mel PIC BASIC Pro
    Last Post: - 30th December 2005, 16:36
  5. program memory size
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 25th October 2005, 20:45
