Yeah well, at least I contributed SOMETHING! LOL
This is a major game-changer for field updates. The approach should also work fine for PIC16F88's.
I'll try to create a somewhat "generic" windows firmware updater based on this approach, with VB6 in the next little while and post it for others to use. It will only be able to Xfer a file IN (PIC readcode dump-->PC), and send a file OUT (PC-->PIC firmware update). It will NOT have encryption built into it, since that's also critically dependent upon a PIC decryption subroutine.
Did you manage to successfully pass variables from your "main program" to your "bootloader" section? If so, did you declare them in BOTH, or was that the purpose of your BLOCKSIZE declaration as a system variable, so it would be accessible for the upper memory AND the resident program?
picster
