Problem with 10-bit A/D conversion - PIC18F2455 - LCD
Results 1 to 10 of 10
Threaded View
  1. #10
    Oct 2009
    Utah, USA
    Default Re: Problem with 10-bit A/D conversion - PIC18F2455 - LCD
    Hey Kuba230,
    Thanks for posting the picture. So to me the picture says a lot... It definitely shows a problem with the LCD but it also shows that your code is working, more or less.
    I would submit that if others that posted comments about checking your register settings and AD setup would have known your display looked like that they would have suggested a problem with the LCD before talking about your code setup.
    It's obvious that you were smart enough to recognize that there was an issue with the LCD and you replaced the defective display.
    The reason I am focusing in on the idea of accurately describing your problem is because I have spent the last several days working with a new electronic technician and trying to teach troubleshooting techniques. It has become clear to me that it is very important for one (anyone) to really think about what the symptoms in a given circuit are telling you, and if you are inviting others to make suggestions then the more accurate you can describe the problem then the more accurate will be the feedback.
    Really just an academic point of learning to better communicate both with others and with ourselves.
    cheers
    dwight
    Dwight
  1. 16 bit conversion - AM2302
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 12th April 2015, 01:34
  2. Replies: 1
    Last Post: - 13th March 2012, 00:34
  3. Conversion Problem
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 18th March 2007, 13:09
  4. Bit conversion
    Last Post: - 5th November 2006, 12:11
  5. Conversion of 10-bit word into ASCII
    By Barry Johnson in forum mel PIC BASIC Pro
    Last Post: - 16th January 2005, 15:26
