i'm a bit rusty on xc8 and as dave says this is a pbp forum not C
but for what its worth
Code:/* * File: TestXC8.c * Author: Dymentional * * Created on April 25, 2016, 2:11 PM */ #include <xc.h> #include <stdio.h> #include <stdlib.h> #include <pic16f1519.h> not sure this is going to help , if project set up correctly in mplabx this is unnecessary #include <htc.h> #include <TestXC8.h> // will help #define led1 PORTB.F0 //RB0 ????????????????? /* * */ int main(int argc, char** argv) { OSCCON = 0x72; //Configure le registre OSCCON en oscillateur interne PORTB = 0b11111111; //Init des pattes du µcontroleur TRISB = 0b11111110; //Bit 0 du Port B en sortie /*while (1) { LATBbits.LATB0 = ~LATBbits.LATB0; //crée une boucle de 1s for (int countDelay=0; countDelay <20; countDelay ++)__delay_ms(50); } }*/he while(1)n I { //Delay ~1 second (8MHz Internal Clock) __delay_ms(8000000); //specify clock cycles directly no way // delay_ms is delay milliseconds not clockcycles // the function prototype uses ints which limits range to much less than 8000000,from memory its less than 1000 ms depending on clock } }
