Outside the Mainloop
Results 1 to 11 of 11
    Default Re: Outside the Mainloop
    Except for the colon in the line GOSUB Init: I don't see any issues with this piece of code. Make sure ALL subroutines ends with a RETURN. If you GOTO something FROM a subroutine then makes sure THAT piece of code ends with a RETURN. That's all the advice I can give you ATM.
    You'd be much better helped if you boil down your ACTUAL code to something small that still shows the error and post that.
    I used to write like you, except with the END as commented by Henrik.
    I have since changed to how I've seen countless examples here:
    Define variables and stuff
    GOTO ProgramStart
    Subroutine1:
      bla bla
    ProgramStart:
      bla bla
      GOSUB Subroutine1
      GOTO ProgramStart
    Your code "should" work. But I've never had a freaky situation by coding like this yet.
    Dec 2010
    GOSUB init not GOSUB init: (which would then be a label)
    MAINLOOP and mainloop are different things.
    Post your actual code and we will help you find the other (likely) typos.
    No, they're not in this case. PBP is not case sensitive.
    Apr 2016
    Plainfield, Illinois
    ok - thanks - I will... I'm currently trying to HPWM a set of LEDs with a 12F683 next so I'll give that shot. I havea degree in CS - JAVA and C++, but haven't used it since college. I'm 60 years old this year - not kidding.. never too late.
    Dec 2010
    I stand corrected - labels are not case sensitive. Most other things are, however.
    Hi Charlie,
    I'll elaborate a bit further: PBP is not case sensitive. The case of labels, commands, variables, constants, modifiers doesn't matter - not case sensitive.
    It's only the case of the "things" that gets passed directly to the assembler (like anything coming after the keyword DEFINE or if you're using inline assembly) that matters because the assembler (MPASM(X)) IS case sensitive.
    Dec 2010
    I checked the manual twice and it agrees with you, however I distinctly remember fixing a bug where I had mixed up capitalized variables and non-capitalized variables. (and I don't think it being passed to the assembler) Nevertheless, sorry for giving bad advice. In this case good form and good function are not necessarily related :-)
