ADCIN Help
Results 1 to 2 of 2
Thread: ADCIN Help
    Tear's Avatar
    Tear Guest
    Default ADCIN Help
    Using the ADCIN command allows for the use of an analog signal to the microcontroller. Looking at the example code on the webpage the whole PORTA is set as analog inputs. Is this because each I/O pin holds a bit? And if so which pin do you wire the input analog signal to? Also since I am measuring an analog signal that will range from 0-5V how many bits do I need to set the ADC to when all I want to do is measure if it is above 0V?
    Michael
    Feb 2004
    Germany
    Tear,
    there is definitely no need to post the very same thing on two (or more) different threads.
    please see this
    (you have at least three different threads regarding the same thing!)
    I would also recommend to read the 12F629 Datasheet and PBP Manual.
    (There is NO A/D-converter on the 12F629)
    regards
    Ralph
  1. ADCIN and PIC18F4331 Arghhhhh !
    By GrandPa in forum mel PIC BASIC Pro
    Last Post: - 6th December 2010, 21:27
  2. How to make adcin stable?
    Last Post: - 20th January 2009, 08:41
  3. ADCIN problems with PIC16F73
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 26th July 2007, 12:38
  4. ADCIN - AD settings are wrong
    By teverett in forum mel PIC BASIC Pro
    Last Post: - 4th December 2006, 17:32
  5. help using adcin
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 31st January 2006, 08:46
