Long / short press button...but reading ADC
Results 1 to 38 of 38
    Aug 2011
    Default Re: Long / short press button...but reading ADC
    Another thing that the sort and average routine in post #11 does is to perform the routine twice and compare the two resulting averages before declaring "I see a valid key" (if adca=adcb then gosub efectuez).
    That could be adapted to fit into the "check_sw" portion of your code by changing some of the post#11 averaging variables around and only
    changing the "result" DataW on a match...
    if adca=adcb then
      DataW = adca
    How well all that works depends on the noise, how many switches (and how far apart the values are), etc, but I could see where it'd be better than just using a single adc value for sure.
    if anyone is interested I do have a multiple button version that is complete and works
    Sure. Love to see it.
    Dec 2008
    Ploiesti, ROMANIA
    Thank you all for support !
    Very interesting suggestions and points-of-view ...
    @Richard :
    if anyone is interested I do have a multiple button version that is complete and works ...
    Of course !!!
    Nov 2007
    West Covina, CA
    I could be wrong but I have to ask about using "CALL" instead of GOSUB for the sub routines CHECK and achizitie.
    From the MCS Help section:
    CALL Label
    Execute the assembly language subroutine named Label. GOSUB is normally used to execute a PicBasic subroutine. The main difference between GOSUB and CALL is that with CALL, the existence of Label is not checked until assembly time. Using CALL, a Label in an assembly language section can be accessed that is otherwise inaccessible to PicBasic.
    Example
    CALL pass ' Execute assembly language subroutine named _pass
    I've never used it in place of GOSUB so don't know if a RETURN works the same in this case.
    Louie
    I've done multi-button with long press (and timed no-button auto-backout) on a '88 using ADC to save pins, and it worked fine, but field EMF noise can wreak absolute havoc on your results (fluorescent lights much?) if you're not using twisted, and preferably shielded wire. That could be what's throwing you out of your "consistent" results needed to qualify for a long-press. Ceradiodes or double-zeners can bleed off freak transients, and a capacitor at the chip A/D input pin would help smooth things out.
    Dec 2008
    Ploiesti, ROMANIA
    @Mr.Richard : Tried to figure out how your soft work ... But in Proteus nothing happens.
    I do something wrong ? I "addapted" the "elseif" command, since is not present in PBP 2.6 (?).
    Thanks in advance for support !
    ;pic12f683
    DEFINE OSC  8
    include "dt_ints-14.bas"
    include "REENTERPBP.bas"
    @timer1 =TMR1L
    wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    INT_LIST  macro    ; IntSource,        Label,           Type,   ResetFlag?
            INT_Handler   TMR1_INT,   _chk_sw,      PBP,  yes
        INT_CREATE
    long_press_threshold   con 200   ;1 sec       200*5( time const)=1000mS
    short_press_threshold  con 5
    btn_tol                con 25   ;ADC READING TOLORACE
    number_of_buttons      con 3    ;MAX 7
    ;4K7 TO 5V
    '                               3k3            /
    '                         ___  /\  /\  /\  ___/ ^____ btn1
    '   5v     4k7           |       2k2           /     |
    '    ___  /\  /\  /\  ___!___  /\  /\  /\  ___/ ^____!btn2
    '                        |       1k            /     |
    '    ____________________!___  /\  /\  /\  ___/ ^____!btn3
    '    an3  gpio4              \/  \/  \/  \/          |
    '    ________________________________________________!
    '    gnd                                             |
    '    ___________|\|__led_____________________________|
    '    gpio2      |/|
    OSCCON=$70
    CMCON0    = 7
    TRISIO   = %111011
    ANSEL    = %01011000        ;fosc/16 ,an3
    btn_adc var word[number_of_buttons]
    b_cnt   var byte[number_of_buttons]
    b_state var byte[number_of_buttons]     ;0 not pressed ,1 short ,2 long
    button_index  var byte      ;which button
    led           var gpio.2    ;led
    btn_flg       var byte
    abp           var BIT
    adcr          var WORD 	    ;adc reading
    timer1        VAR WORD EXT
    tmp           var word
    FLASH_ON      VAR WORD      ;led
    FLASH_OFF     VAR WORD      ;led
    FLASH_DUTY    VAR WORD      ;led
    led = 0
    clear
    btn_adc[0]=209           ;adc read for buttons
    btn_adc[1]=327           ;adc read for buttons
    btn_adc[2]=422           ;adc read for buttons
    timer1=55543             ;5mS  time const
    T1CON=1
    @ INT_ENABLE  TMR1_INT
    FLASH_OFF=200
    FLASH_On=0
    ADCON0 = %10001101     ;warm up the adc  ,right shift   ,an3
    ADCON0.1 = 1            ' Start a conversion
       Pause 5   ;loop time const
        IF ABP THEN
           button_index= 0
           tmp=20
           while abp
               if  B_STATE[button_index]=2 then
                   FLASH_OFF= tmp
                   abp=0
                   led=0
                   FLASH_DUTY=0
                   if   B_STATE[button_index]=1 then
                   FLASH_On=tmp
                   abp=0
                   led=0
                   FLASH_DUTY=0
               tmp=tmp+100
               B_STATE[button_index]=0
               button_index=button_index+1
               if  button_index= number_of_buttons then abp=0  ;clr error  if req
            wend
         IF  FLASH_ON THEN
           IF FLASH_DUTY=0 THEN
           led = ! LED     ; flash led
            	IF LED THEN
             	FLASH_DUTY = FLASH_ON
             	FLASH_DUTY = FLASH_OFF
           FLASH_DUTY=FLASH_DUTY-1
    Goto Main
    chk_sw:
        T1CON.0=0
        timer1=timer1+55543
        T1CON.0=1
        ;ADCON0 = %10001101 ; NO NEED since ch never changes and ADC is left ON
        ;Pauseus 50		'  aqusition  time  if req
        ;ADCON0.1 = 1		' Start conversion
        ;While ADCON0.1=1:Wend	' Wait for conversion
        adcr.HighByte = ADRESH	' Read variable from ADC
        adcr.LowByte  = ADRESL
        FOR button_index = 0 TO 2
              if ! B_STATE[button_index] then
                  IF    abs (adcr- btn_adc[button_index] )< btn_tol  then
                       if  btn_flg.0[button_index]  THEN
                            IF b_cnt[button_index] < 250 THEN  b_cnt[button_index]=b_cnt[button_index]+1
                            ELSE   ;FIRST PRESS  FOR  THIS BUTTON
                            b_cnt[button_index]=0
                            btn_flg.0[button_index]=1
                       IF   btn_flg.0[button_index]  THEN    ;  HAD   THIS BUTTON  BEEN PRESSED  ?
                           IF   b_cnt[button_index] > long_press_threshold THEN
                           abp=1
                           IF   b_cnt[button_index] > short_press_threshold THEN
                           B_STATE[button_index] =1
                           abp=1
                       btn_flg.0[button_index]=0
        next
        ADCON0.1 = 1     ' Start conversion  for next pass
    @ INT_RETURN
    did you try it on a real chip ?
    the led should have a series resistor to limit current , I assumed that would be obvious and omitted it from the sketch
    @ 5v try 180 ohm for a yellow led
  1. Replies: 5
    Last Post: - 26th February 2011, 05:51
  2. Button press or not
    Last Post: - 24th November 2010, 20:37
  3. 4 Bytes one button press
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 15th January 2010, 22:36
  4. Sleep until button press?
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 9th October 2007, 03:47
  5. Button press and press & hold how to ?
    By GrandPa in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2007, 03:37
